Installation & Licensing
network license borrowing
1 REPLY 1
bradskin
173 Views, 1 Reply
I want to put 2005 on my machine at home.
How do I install Acad without a license?
How do I borrow a network license?
How do I get it home?
Where do I put the license on my machine?
1 REPLY 1
TravisNave
in reply to: bradskin
Well, first we need some more information about your copy of AutoCAD...
"I want to put 2005 on my machine at home."
- Okay, is it your copy or a company owned copy? The EULA allows for a second install, provided you only use one at a time. Read the EULA for more information.
"How do I install Acad without a license?"
- You can install AutoCAD as a 30-day trial. Is your copy a Stand-alone or a Network version?
"How do I borrow a network license?"
- Tools > License Borrowing > Borrow License
(Assuming you have a License Server a.k.a. FlexLM)
"How do I get it home?"
- If it is your copy, just take it home. If not, I can not advise you to steal the CD or the License.
"Where do I put the license on my machine?"
- If you borrow a license, it will do it Automatically. If you install a second stand-alone copy (legally) you can just re-Authorize the installation thru the Internet or your Reseller.
Hope this helps lead you in the right path.
Autodesk Forums:
Administrator Productivity
