Hi sandip,
First :
verify that your FlexLM Service is correctly configured.
To do :
When you launch LMtools, specify "Configuration using services".
Go to "Config services".
Give all informations for the lmgrd.exe, license file and debug log file
(create a blank file if none).
Mark "Start server at power up" and "Use services".
Click on "Save service".
Second :
verify that "adskflex.exe" is present in your directory "C:\Program
Files\Autodesk License Manager"
because your last line of your log said :
10:17:44 (lmgrd) File not found, adskflex.exe
Third :
Disable all Firewall and Anti-virus (just for test).
Franck Hervet
www.aricad.fr
a écrit dans le message de news: 5135362@discussion.autodesk.com...
sorry i cud make an attachment. so i am posting here.
log files detials:
10:13:29 (lmgrd) -----------------------------------------------
10:13:29 (lmgrd) Please Note:
10:13:29 (lmgrd)
10:13:29 (lmgrd) This log is intended for debug purposes only.
10:13:29 (lmgrd) In order to capture accurate license
10:13:29 (lmgrd) usage data into an organized repository,
10:13:29 (lmgrd) please enable report logging. Use Macrovision's
10:13:29 (lmgrd) software license administration solution,
10:13:29 (lmgrd) FLEXnet Manager, to readily gain visibility
10:13:29 (lmgrd) into license usage data and to create
10:13:29 (lmgrd) insightful reports on critical information like
10:13:29 (lmgrd) license availability and usage. FLEXnet Manager
10:13:29 (lmgrd) can be fully automated to run these reports on
10:13:29 (lmgrd) schedule and can be used to track license
10:13:29 (lmgrd) servers and usage across a heterogeneous
10:13:29 (lmgrd) network of servers including Windows NT, Linux
10:13:29 (lmgrd) and UNIX. Contact Macrovision at
10:13:29 (lmgrd) www.macrovision.com for more details on how to
10:13:29 (lmgrd) obtain an evaluation copy of FLEXnet Manager
10:13:29 (lmgrd) for your enterprise.
10:13:29 (lmgrd)
10:13:29 (lmgrd)
10:13:29 (lmgrd)
10:13:29 (lmgrd) pid 2728
10:13:29 (lmgrd) Detecting other license server manager (lmgrd) processes...
10:13:29 (lmgrd) Done rereading
10:13:29 (lmgrd) FLEXnet Licensing (v10.1.5) started on GRM-KHA-BC-AC (IBM
PC) (4/7/2006)
10:13:29 (lmgrd) Copyright (c) 1988-2004 by Macrovision Corporation. All
rights reserved.
10:13:29 (lmgrd) US Patents 5,390,297 and 5,671,412.
10:13:29 (lmgrd) World Wide Web: http://www.macrovision.com
10:13:29 (lmgrd) License file(s): C:\Program Files\Autodesk License
Manager\340-36324343.lic
10:13:29 (lmgrd) lmgrd tcp-port 27000
10:13:29 (lmgrd) Starting vendor daemons ...
10:13:29 (lmgrd) Starting vendor daemon at port 2080
10:13:29 (lmgrd) Using vendor daemon port 2080 specified in license file
10:13:29 (lmgrd) Started adskflex (pid 3552)
10:13:29 (adskflex) FLEXnet Licensing version 10.1.5
10:13:29 (adskflex) Server started on GRM-KHA-BC-AC for: 40900INVBUN_5_0F
10:13:30 (adskflex) Vendor daemon can't talk to the license server manager
(lmgrd) (Cannot connect to license server system. (-15,10:10061 "WinSock:
Connection refused"))
10:13:44 (lmgrd) Vendor daemon died with status 28
10:13:44 (lmgrd) Since this is an unknown status, license server
10:13:44 (lmgrd) manager (lmgrd) will attempt to re-start the vendor daemon.
10:13:44 (lmgrd) Starting vendor daemon at port 2080
10:13:44 (lmgrd) Using vendor daemon port 2080 specified in license file
10:13:44 (lmgrd) REStarted adskflex (pid 2944)
10:13:44 (adskflex) FLEXnet Licensing version 10.1.5
10:13:44 (adskflex) Server started on GRM-KHA-BC-AC for: 40900INVBUN_5_0F
10:13:45 (adskflex) Vendor daemon can't talk to the license server manager
10:13:59 (lmgrd) Vendor daemon died with status 28
10:13:59 (lmgrd) Since this is an unknown status, license server
10:13:59 (lmgrd) manager (lmgrd) will attempt to re-start the vendor daemon.
10:13:59 (lmgrd) Starting vendor daemon at port 2080
10:13:59 (lmgrd) Using vendor daemon port 2080 specified in license file
10:13:59 (lmgrd) REStarted adskflex (pid 1664)
10:13:59 (adskflex) FLEXnet Licensing version 10.1.5
10:13:59 (adskflex) Server started on GRM-KHA-BC-AC for: 40900INVBUN_5_0F
10:14:00 (adskflex) Vendor daemon can't talk to the license server manager
10:14:14 (lmgrd) Vendor daemon died with status 28
10:14:14 (lmgrd) Since this is an unknown status, license server
10:14:14 (lmgrd) manager (lmgrd) will attempt to re-start the vendor daemon.
10:14:14 (lmgrd) Starting vendor daemon at port 2080
10:14:14 (lmgrd) Using vendor daemon port 2080 specified in license file
10:14:14 (lmgrd) REStarted adskflex (pid 2604)
10:14:14 (adskflex) FLEXnet Licensing version 10.1.5
10:14:14 (adskflex) Server started on GRM-KHA-BC-AC for: 40900INVBUN_5_0F
10:14:15 (adskflex) Vendor daemon can't talk to the license server manager
10:14:29 (lmgrd) Vendor daemon died with status 28
10:14:29 (lmgrd) Since this is an unknown status, license server
10:14:29 (lmgrd) manager (lmgrd) will attempt to re-start the vendor daemon.
10:14:29 (lmgrd) Starting vendor daemon at port 2080
10:14:29 (lmgrd) Using vendor daemon port 2080 specified in license file
10:14:29 (lmgrd) REStarted adskflex (pid 3604)
10:14:29 (adskflex) FLEXnet Licensing version 10.1.5
10:14:29 (adskflex) Server started on GRM-KHA-BC-AC for: 40900INVBUN_5_0F
10:14:30 (adskflex) Vendor daemon can't talk to the license server manager
10:14:44 (lmgrd) Vendor daemon died with status 28
10:14:44 (lmgrd) Since this is an unknown status, license server
10:14:44 (lmgrd) manager (lmgrd) will attempt to re-start the vendor daemon.
10:14:44 (lmgrd) Starting vendor daemon at port 2080
10:14:44 (lmgrd) Using vendor daemon port 2080 specified in license file
10:14:44 (lmgrd) REStarted adskflex (pid 904)
10:14:44 (adskflex) FLEXnet Licensing version 10.1.5
10:14:44 (adskflex) Server started on GRM-KHA-BC-AC for: 40900INVBUN_5_0F
10:14:45 (adskflex) Vendor daemon can't talk to the license server manager
10:14:59 (lmgrd) Vendor daemon died with status 28
10:14:59 (lmgrd) Since this is an unknown status, license server
10:14:59 (lmgrd) manager (lmgrd) will attempt to re-start the vendor daemon.
10:14:59 (lmgrd) Starting vendor daemon at port 2080
10:14:59 (lmgrd) Using vendor daemon port 2080 specified in license file
10:14:59 (lmgrd) REStarted adskflex (pid 3760)
10:14:59 (adskflex) FLEXnet Licensing version 10.1.5
10:14:59 (adskflex) Server started on GRM-KHA-BC-AC for: 40900INVBUN_5_0F
10:15:00 (adskflex) Vendor daemon can't talk to the license server manager
10:15:14 (lmgrd) Vendor daemon died with status 28
10:15:14 (lmgrd) Since this is an unknown status, license server
10:15:14 (lmgrd) manager (lmgrd) will attempt to re-start the vendor daemon.
10:15:14 (lmgrd) Starting vendor daemon at port 2080
10:15:14 (lmgrd) Using vendor daemon port 2080 specified in license file
10:15:14 (lmgrd) REStarted adskflex (pid 4020)
10:15:14 (adskflex) FLEXnet Licensing version 10.1.5
10:15:14 (adskflex) Server started on GRM-KHA-BC-AC for: 40900INVBUN_5_0F
10:15:15 (adskflex) Vendor daemon can't talk to the license server manager
10:15:29 (lmgrd) Vendor daemon died with status 28
10:15:29 (lmgrd) Since this is an unknown status, license server
10:15:29 (lmgrd) manager (lmgrd) will attempt to re-start the vendor daemon.
10:15:29 (lmgrd) Starting vendor daemon at port 2080
10:15:29 (lmgrd) Using vendor daemon port 2080 specified in license file
10:15:29 (lmgrd) REStarted adskflex (pid 3000)
10:15:29 (adskflex) FLEXnet Licensing version 10.1.5
10:15:29 (adskflex) Server started on GRM-KHA-BC-AC for: 40900INVBUN_5_0F
10:15:30 (adskflex) Vendor daemon can't talk to the license server manager
10:15:44 (lmgrd) Vendor daemon died with status 28
10:15:44 (lmgrd) Since this is an unknown status, license server
10:15:44 (lmgrd) manager (lmgrd) will attempt to re-start the vendor daemon.
10:15:44 (lmgrd) Starting vendor daemon at port 2080
10:15:44 (lmgrd) Using vendor daemon port 2080 specified in license file
10:15:44 (lmgrd) REStarted adskflex (pid 3448)
10:15:44 (adskflex) FLEXnet Licensing version 10.1.5
10:15:44 (adskflex) Server started on GRM-KHA-BC-AC for: 40900INVBUN_5_0F
10:15:45 (adskflex) Vendor daemon can't talk to the license server manager
10:15:59 (lmgrd) Vendor daemon died with status 28
10:15:59 (lmgrd) Since this is an unknown status, license server
10:15:59 (lmgrd) manager (lmgrd) will attempt to re-start the vendor daemon.
10:15:59 (lmgrd) Starting vendor daemon at port 2080
10:15:59 (lmgrd) Using vendor daemon port 2080 specified in license file
10:15:59 (lmgrd) REStarted adskflex (pid 3340)
10:15:59 (adskflex) FLEXnet Licensing version 10.1.5
10:15:59 (adskflex) Server started on GRM-KHA-BC-AC for: 40900INVBUN_5_0F
10:16:00 (adskflex) Vendor daemon can't talk to the license server manager
10:16:14 (lmgrd) Vendor daemon died with status 28
10:16:14 (lmgrd) Since this is an unknown status, license server
10:16:14 (lmgrd) manager (lmgrd) will attempt to re-start the vendor daemon.
10:16:14 (lmgrd) Starting vendor daemon at port 2080
10:16:14 (lmgrd) Using vendor daemon port 2080 specified in license file
10:16:14 (lmgrd) REStarted adskflex (pid 2428)
10:16:14 (adskflex) FLEXnet Licensing version 10.1.5
10:16:14 (adskflex) Server started on GRM-KHA-BC-AC for: 40900INVBUN_5_0F
10:16:15 (adskflex) Vendor daemon can't talk to the license server manager
10:16:29 (lmgrd) Vendor daemon died with status 28
10:16:29 (lmgrd) Since this is an unknown status, license server
10:16:29 (lmgrd) manager (lmgrd) will attempt to re-start the vendor daemon.
10:16:29 (lmgrd) Starting vendor daemon at port 2080
10:16:29 (lmgrd) Using vendor daemon port 2080 specified in license file
10:16:29 (lmgrd) REStarted adskflex (pid 740)
10:16:29 (adskflex) FLEXnet Licensing version 10.1.5
10:16:29 (adskflex) Server started on GRM-KHA-BC-AC for: 40900INVBUN_5_0F
10:16:30 (adskflex) Vendor daemon can't talk to the license server manager
10:16:44 (lmgrd) Vendor daemon died with status 28
10:16:44 (lmgrd) Since this is an unknown status, license server
10:16:44 (lmgrd) manager (lmgrd) will attempt to re-start the vendor daemon.
10:16:44 (lmgrd) Starting vendor daemon at port 2080
10:16:44 (lmgrd) Using vendor daemon port 2080 specified in license file
10:16:44 (lmgrd) REStarted adskflex (pid 3548)
10:16:44 (adskflex) FLEXnet Licensing version 10.1.5
10:16:44 (adskflex) Server started on GRM-KHA-BC-AC for: 40900INVBUN_5_0F
10:16:45 (adskflex) Vendor daemon can't talk to the license server manager
10:16:59 (lmgrd) Vendor daemon died with status 28
10:16:59 (lmgrd) Since this is an unknown status, license server
10:16:59 (lmgrd) manager (lmgrd) will attempt to re-start the vendor daemon.
10:16:59 (lmgrd) Starting vendor daemon at port 2080
10:16:59 (lmgrd) Using vendor daemon port 2080 specified in license file
10:16:59 (lmgrd) REStarted adskflex (pid 668)
10:16:59 (adskflex) FLEXnet Licensing version 10.1.5
10:16:59 (adskflex) Server started on GRM-KHA-BC-AC for: 40900INVBUN_5_0F
10:17:00 (adskflex) Vendor daemon can't talk to the license server manager
10:17:14 (lmgrd) Vendor daemon died with status 28
10:17:14 (lmgrd) Since this is an unknown status, license server
10:17:14 (lmgrd) manager (lmgrd) will attempt to re-start the vendor daemon.
10:17:14 (lmgrd) Starting vendor daemon at port 2080
10:17:14 (lmgrd) Using vendor daemon port 2080 specified in license file
10:17:14 (lmgrd) REStarted adskflex (pid 3924)
10:17:14 (adskflex) FLEXnet Licensing version 10.1.5
10:17:14 (adskflex) Server started on GRM-KHA-BC-AC for: 40900INVBUN_5_0F
10:17:15 (adskflex) Vendor daemon can't talk to the license server manager
10:17:29 (lmgrd) Vendor daemon died with status 28
10:17:29 (lmgrd) Since this is an unknown status, license server
10:17:29 (lmgrd) manager (lmgrd) will attempt to re-start the vendor daemon.
10:17:29 (lmgrd) Starting vendor daemon at port 2080
10:17:29 (lmgrd) Using vendor daemon port 2080 specified in license file
10:17:29 (lmgrd) REStarted adskflex (pid 3336)
10:17:29 (adskflex) FLEXnet Licensing version 10.1.5
10:17:29 (adskflex) Server started on GRM-KHA-BC-AC for: 40900INVBUN_5_0F
10:17:30 (adskflex) Vendor daemon can't talk to the license server manager
10:17:44 (lmgrd) Vendor daemon died with status 28
10:17:44 (lmgrd) Since this is an unknown status, license server
10:17:44 (lmgrd) manager (lmgrd) will attempt to re-start the vendor daemon.
10:17:44 (lmgrd) Starting vendor daemon at port 2080
10:17:44 (lmgrd) Using vendor daemon port 2080 specified in license file
10:17:44 (lmgrd) License server manager (lmgrd) startup failed:
now lic file detiails:
SERVER grm-kha-bc-ac 00110A864E27
USE_SERVER
VENDOR adskflex port=27000
INCREMENT 40900INVBUN_5_0F adskflex 1.000 permanent 3 \
VENDOR_STRING=commercial:permanent SUPERSEDE DUP_GROUP=UH \
ISSUED=24-Jan-2006 SN=xxx-xxxxxxxx SIGN=6E7114287FBE
