a message came up saying: you have not made changes to the default configuration that will be used to install the chosen product(s) Do you want to continue installing using the default configuration?
Solved by nestly. Go to Solution.
That just means you selected to do a "Custom Install" but all your settings were exactly the same a the "default" settings. If those are the settings you want, just continue
