Installation & Licensing
install autocad 2011
7 REPLIES 7
Message 1 of 8
1386 Views, 7 Replies
i can reach to install the autocad 2011 on my windows 7. first,  he says that i have already an autocad design review 2011 installed on my computer, and after instalations, when i start the program, the autocad begins again the setup.
Please help me!!!!!
Tags (2)
7 REPLIES 7
Message 2 of 8
TravisNave
Message 3 of 8
I was able to fix the autodesk design review 11 problem, but i still having problems installing the autocad2011. After instalation, when i run the program he restarts the setup.
On the desktop screen he appears as exe. file. what´s the problem???
Message 4 of 8
TravisNave
Run the program from the AutoCAD 2011 icon in your Start menu under All Programs > Autodesk.
Autodesk Forums:
Message 5 of 8
i´m getting frustrated. I still with the same problem. he ask me to do the setup agian.
please help......
Message 6 of 8
abiudsilva12
window7 32bits
silva
Message 7 of 8
TravisNave
If you do not have local admin rights on your machine or if you are using roaming profiles, then this could be your problem.
Autodesk Forums:
Message 8 of 8
in reply to: TravisNave
I'm having an issue getting AutoCAD Architecture 2011 to run after completing the install.  I get a message saying "Unable to run AutoCad" either because it did not install properly or i don't have sufficient right to run it.  I have installed it twice now and the install says it was a success.  I have only one login to my computer and it has all the admin rights.  I had Architecture 2012 installed and was able to use it, but because we use 2011 in class I uninstalled it and installed Architecture 2011 instead.  Since I was already running the 2012 version and it worked, I don't see how it could be a PC permissions issue.  Any suggestions as to what could be causing this problem?
Administrator Productivity
