Installation & Licensing
New Member
Message 1 of 7 (7,790 Views)
Accepted Solution
fatal error Unhandled Access violation Reading 0xfffffff Exception at e78c0004h
7790 Views, 6 Replies
01-22-2013 06:19 PM
I recently installed AutoCAD 2013 onto my computer which has windows 7 64 bit operating system. After completing installation, I tried to open AutoCAD and immediatly I recieved this error, "Fatal error: Unhandled Access violation Reading 0xffffffff Exception at e78c0004h. I was wondering if anybody knows what that error is signaling and could help me resolve the problem. Thank you!
*Expert Elite*
TravisNave
Message 2 of 7 (7,720 Views)
Re: fatal error Unhandled Access violation Reading 0xfffffff Exception at e78c00
01-24-2013 08:16 AM in reply to: evan.g.mcmahon
Make sure you have local admin rights and a certified video driver.  You should also test in another local administrator login to eliminate a profile issue.  If all of those still fail, you might have to reinstall your .NET Framework.
.NET Framework issues can be resolved using the .NET Framework Cleanup Tool. More information about this tool can be found at my discussion thread here:
http://forums.autodesk.com/t5/Installation-Licensing/NET-Framework-Cleanup-Tool-for-Unhandled-Except...
Good Luck!
Travis Nave Send TravisNave a Private Message                       Need help in your post? Mention me with @TravisNave
New Member
Message 3 of 7 (7,692 Views)
01-25-2013 01:08 PM in reply to: TravisNave
The problem was my video card. I have a gtx 660m with optimus and I was getting the error on my dedicated card. I went into my nvidia preferences told it to run autocad using my integrated intel 4000 video card which did the trick. Thank you for all the help, much appreciated!
Thanks!
*Expert Elite*
TravisNave
Message 4 of 7 (7,687 Views)
01-25-2013 01:21 PM in reply to: evan.g.mcmahon
Thanks for following up.  Hopefully it will help the next person!
New Member
Message 5 of 7 (6,554 Views)
05-05-2013 03:52 AM in reply to: evan.g.mcmahon
I have the same problem with a new Dell laptop Inspiron 17, running Win 7 Enterprise, having Intel 4000 and ATI Radeon 7600 video cards (why 2?). How do I disable this feature in Radeon? I updated the drivers but didn't find this option.
New Member
Message 6 of 7 (1,114 Views)
02-22-2014 02:13 PM in reply to: evan.g.mcmahon
Thank you so much, it solved my fatal error:"unhandled acceess violation reading 0xfffffffexception at e4ee004h". The problem was caused my nvidia video card too.
New Member
Message 7 of 7 (623 Views)
03-14-2014 02:49 PM in reply to: evan.g.mcmahon
when i start it mine says fatal error Unhandled Access violation Reading 0xfffffff Exception at e6390004h and  an other pop-up saying liscences autodesk.
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Connect with Us
Twitter
Pinterest
Blog
Youtube
