I am having problems installing architecture 2014. it fails to install everytime I try to install.
I had the same issues with 2013 architecture, I have just been working off of standard autocad for the past year.
any suggestions would be greatly appreciated.
It's failing on Sketchbook. Uncheck it during the installation. You probably don't need it. You should be good on the rest. If others fail, repost.
Install Autodesk® SketchBook® Designer 2014 Failed Installation aborted, Result=1603
I figured out my issue.
autodesk support had me re-path my temp files and that fixed my issues
