I'm tring to register/activate my resent purchase of Maya 2011. When i get to the screen asking for my serial number i enter what is writen on the packaging, i hit enter, and it says:
The serial number you entered is not valid for the product you are trying to activate. Try again. (Error 123)
when i click on the little question mark next to the "enter product serial number" it says:
Note: if you are a subscription customer, you must install and activate your software using your Group ID.
I am a subscription customer, where do i find this Group ID?
thanks
Alberto
Solved by david.lau. Go to Solution.
I was able to check the database and it appears you have a network license. If you use a network license to activate, the system will error out as the serial number is 'Network' and not "Standalone".
If you are tryiing to change the install from Standalone to Network, you can check out this video:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?linkID=9242258&id=14068656&siteID=123112
