I received an error message stating "adu18res.dll not found" when I tried launching AutoCAD. I am attempting to install AutoCAD 2010 Student Version on to a machine(64 bits) with a Vista Ultimate OS. I have attempted to uninstall what appears to be two instances of the program; via the control panel, the program will not uninstall. If I was able to unstall, I would re-install the program. Please provide me with a solution to this problem.
Your help would be appeciated.
Andy Mobley
Please refer to Case ID 2950316
I hawe got the same problem!!!! HELP!
Its language pack installation failure which is causing the issue.
Please try to install the software in diagnostics mode as described here.
http://usa.autodesk.com/getdoc/id=TS75218
If the issue persisits, please post the all the log files from the %temp% folder (start->run/search->type %temp% ->Enter) as a zip file.
