When installing VW2011, I get an error during pre-check that reads "An older version of SQL server is used for an existing Vault database instance." I am unable to go any furhter with the install. I have SQL Sever 2005 Express sp-3 installed. Any help would be sappreciated.
David Russell
QED, Inc.
Solved by minkd. Go to Solution.
Did you already have a previous version of Vault installed? Or perhaps and older Inventor installed with a local content center?
Vault Workgroup 2010 is installed. This is on our server machine, no inventor or content center.
I do not believe you can have more than one version of Vault installed.
