Installation & Licensing
Update to 2014 and Product Key
9 REPLIES 9
Message 1 of 10
2725 Views, 9 Replies
I have downloaded the update that comes with my subscription.  When I get to the page that you enter the Serial Number and Product Key, the Product Key is not accepted.  I have a 5 charecter Product Key.  The serial numeber gets a green check mark but Product Key gets a red X.
Any suggestions?
9 REPLIES 9
Message 2 of 10
emily.xu
Welcome to Autodesk Community!
Can you tell me what's your product and the product key you entered?
Emily Xu
Product Support
Message 3 of 10
TravisNave
At the time of this post, Autodesk doesn't seem to have a KB link yet for the 2014 product key lists.  However, it most likely will be using the F character for 2014.  So assuming your product was AutoCAD 2013 last year, for example, and your product key was 001E1, then this year's AutoCAD 2014 should be 001F1.  Your product key designation should follow a similar pattern.  Some suites do change, however, so you will want to verify with Autodes, your Reseller, or the Subscription center for accuracy.
How to find your product key in Subscription Center:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=21363461&linkID=16831209
Here is a list of the 2013 keys (try substituting the E with an F for 2014)
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=19726931&linkID=12305695
Autodesk Simulation 2014 keys have been release here:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=21374569&linkID=18154757
I would assume the 2014 list will be released once the entire product line is available.
Autodesk Forums:
Message 4 of 10
in reply to: emily.xu
Product is: AutoCAD 2013 Product Key is: 001F1
Message 5 of 10
DarrenP
2014 product keys are here:http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=21481916&linkID=9240817&CMP=OTC-RSS...
the Autocad 2014 product key is 001F1
DarrenP
Message 6 of 10
DarrenP
in reply to: DarrenP
are you installing 2013 or 2014?
the serial number and product key changes with every release
DarrenP
Message 7 of 10
I have AutoCAD 2013 and recieved an email saying my upgrade is available for download (subscription generated i am sure). So, that being said, I went through the download process and got to the product key and code page, only to find it will not take the product key shown with the "New Serial Number" or the "Current Serial Number" (i printed that page). I am at a loss of what to do. The Product Key is shown as 001F1
Message 8 of 10
philip.s
Hello Sean,
To ensure that you are using the proper licensing info, can you please send me a Private Message (click on my philip.s profile name and then "Send this user a private message") with your new serial number, product key, and a screen shot of the installation / activation screen where it will not accept the info?
Message 9 of 10
in reply to: philip.s
[image: Inline image 1]
Message 10 of 10
emily.xu
If you want to install autocad 2013, use Prodcut Key: 001E1
If install autocad 2014, use Prodcut Key: 001F1
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Emily Xu
Product Support
Administrator Productivity
