Hi Chris,
I believe a 6072 error is license sequence related. That is the license information on the disk is out of sequence.
There are a number of potential causes for this, so you would probably be best obtaining support from your Reseller if you have any.
In this situation it is a good idea anyway to upgrade to the latest license manager run time system, available from
http://support.autodesk.com/getDoc.asp?id=DL402225
Mark Taylor
Product Support, EMEA
WW Support & Services, Autodesk
Discussion Q&A: http://www.autodesk.com/discussion
"donalsteel" wrote in message news:f0d33a9.-1@WebX.maYIadrTaRb...
> After installing a standalone version of Acad2002 on a Win2000 Operating system.I get a reoccuring error with the license manager,
after a few days of being authorized it will prompt me with the following ' Important! in order to continue, you must obtain
additional authorization.Error[6072]'
> I then have to re-authorize the software and sure enough after a couple of days the same message will appear again!
> Any ideas would be most welcome!
> Chris
