Installation & Licensing
Tried to install autocad 2012 but failed.. need help
3 REPLIES 3
jholasca
1033 Views, 3 Replies
2013/3/2:08:52:07 Jerome LAPTOP === Setup started on LAPTOP by Jerome ===
2013/3/2:08:52:07 Jerome LAPTOP Launch
2013/3/2:08:52:13 Jerome LAPTOP === Setup ended ===
2013/3/2:08:52:08 Jerome LAPTOP === Setup started on LAPTOP by Jerome ===
2013/3/2:08:52:08 Jerome LAPTOP Launch
2013/3/2:08:52:13 Jerome LAPTOP PageOpen LaunchDialog
2013/3/2:08:52:26 Jerome LAPTOP PageOpen LicenseDialog
2013/3/2:08:52:39 Jerome LAPTOP PageOpen ProductInfoDialog
2013/3/2:08:53:29 Jerome LAPTOP PageOpen ProductSelectionDialog2
2013/3/2:08:53:40 Jerome LAPTOP PageOpen FullProgressDialog
2013/3/2:08:53:40 Jerome LAPTOP Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): C:\Autodesk\AutoCAD_2012_English_Win_64bit\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe /q
2013/3/2:08:53:46 Jerome LAPTOP Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Succeeded
2013/3/2:08:53:46 Jerome LAPTOP Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): C:\Autodesk\AutoCAD_2012_English_Win_64bit\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe /q
2013/3/2:08:53:51 Jerome LAPTOP Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Succeeded
2013/3/2:08:53:51 Jerome LAPTOP Installing DirectX Runtime: C:\Autodesk\AutoCAD_2012_English_Win_64bit\3rdParty\DirectX\DXSETUP.exe /silent
2013/3/2:08:54:40 Jerome LAPTOP Install DirectX Runtime Succeeded
2013/3/2:08:54:40 Jerome LAPTOP Installing FaroSDK: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/3/2:08:54:52 Jerome LAPTOP Install FaroSDK Succeeded
2013/3/2:08:54:52 Jerome LAPTOP Installing Autodesk Material Library 2012: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/3/2:08:55:09 Jerome LAPTOP Install Autodesk Material Library 2012 Succeeded
2013/3/2:08:55:09 Jerome LAPTOP Installing Autodesk Material Library 2012 - Low Resolution: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/3/2:08:55:46 Jerome LAPTOP Install Autodesk Material Library 2012 - Low Resolution Succeeded
2013/3/2:08:55:46 Jerome LAPTOP Installing Microsoft Visual C++ 2005 Redistributable (x86): C:\Autodesk\AutoCAD_2012_English_Win_64bit\3rdParty\x86\VCRedist\2005\vcredist_x86.exe /q:a /T:C:\windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Jerome\AppData\Local\Temp\vcredist_x86_2005.log"" "
2013/3/2:08:55:52 Jerome LAPTOP Install Microsoft Visual C++ 2005 Redistributable (x86) Succeeded
2013/3/2:08:55:52 Jerome LAPTOP Installing Autodesk Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/3/2:08:56:21 Jerome LAPTOP Install Autodesk Content Service Succeeded
2013/3/2:08:56:29 Jerome LAPTOP Installing AutoCAD® 2012: TRANSFORMS="C:\Autodesk\AutoCAD_2012_English_Win_64bit\x64\en-us\acad\acad.mst;C:\Users\Jerome\AppData\Local\Temp\_AIA92B.tmp\x64\acad\acad-standalone.mst" MSINEWINSTANCE=1 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2012 - English\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/3/2:08:56:43 Jerome LAPTOP Install AutoCAD® 2012 Failed Installation aborted, Result=1603
2013/3/2:08:56:56 Jerome LAPTOP Rollback Autodesk Content Service Succeeded
2013/3/2:08:56:56 Jerome LAPTOP Rollback Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1619
2013/3/2:08:57:17 Jerome LAPTOP Rollback Autodesk Material Library 2012 - Low Resolution Succeeded
2013/3/2:08:57:44 Jerome LAPTOP Rollback Autodesk Material Library 2012 Succeeded
2013/3/2:08:57:45 Jerome LAPTOP Rollback FaroSDK Succeeded
2013/3/2:08:57:45 Jerome LAPTOP Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2013/3/2:08:57:46 Jerome LAPTOP PageOpen InstallCompleteDialog
2013/3/2:08:59:44 Jerome LAPTOP === Setup ended ===
2013/3/2:09:06:20 Jerome LAPTOP === Setup started on LAPTOP by Jerome ===
2013/3/2:09:06:20 Jerome LAPTOP Launch
2013/3/2:09:06:25 Jerome LAPTOP === Setup ended ===
2013/3/2:09:06:22 Jerome LAPTOP PageOpen LaunchDialog
2013/3/2:09:07:43 Jerome LAPTOP PageOpen LicenseDialog
2013/3/2:09:07:56 Jerome LAPTOP PageOpen ProductInfoDialog
2013/3/2:09:08:12 Jerome LAPTOP PageOpen ProductSelectionDialog2
2013/3/2:09:08:20 Jerome LAPTOP PageOpen FullProgressDialog
2013/3/2:09:08:20 Jerome LAPTOP Installing DirectX Runtime: C:\Autodesk\AutoCAD_2012_English_Win_64bit\3rdParty\DirectX\DXSETUP.exe /silent
2013/3/2:09:08:58 Jerome LAPTOP Install DirectX Runtime Succeeded
2013/3/2:09:08:58 Jerome LAPTOP Installing FaroSDK: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/3/2:09:09:04 Jerome LAPTOP Install FaroSDK Succeeded
2013/3/2:09:09:04 Jerome LAPTOP Installing Autodesk Material Library 2012: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/3/2:09:09:29 Jerome LAPTOP Install Autodesk Material Library 2012 Succeeded
2013/3/2:09:09:29 Jerome LAPTOP Installing Autodesk Material Library 2012 - Low Resolution: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/3/2:09:09:54 Jerome LAPTOP Install Autodesk Material Library 2012 - Low Resolution Succeeded
2013/3/2:09:09:54 Jerome LAPTOP Installing Autodesk Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/3/2:09:10:14 Jerome LAPTOP Install Autodesk Content Service Succeeded
2013/3/2:09:10:15 Jerome LAPTOP Installing AutoCAD® 2012: TRANSFORMS="C:\Autodesk\AutoCAD_2012_English_Win_64bit\x64\en-us\acad\acad.mst;C:\Users\Jerome\AppData\Local\Temp\_AIAC95.tmp\x64\acad\acad-standalone.mst" MSINEWINSTANCE=1 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2012 - English\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/3/2:09:11:00 Jerome LAPTOP Install AutoCAD® 2012 Failed Installation aborted, Result=1603
2013/3/2:09:11:08 Jerome LAPTOP Rollback Autodesk Content Service Succeeded
2013/3/2:09:11:23 Jerome LAPTOP Rollback Autodesk Material Library 2012 - Low Resolution Succeeded
2013/3/2:09:11:41 Jerome LAPTOP Rollback Autodesk Material Library 2012 Succeeded
2013/3/2:09:11:42 Jerome LAPTOP Rollback FaroSDK Succeeded
2013/3/2:09:11:42 Jerome LAPTOP Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2013/3/2:09:11:42 Jerome LAPTOP PageOpen InstallCompleteDialog
2013/3/2:09:19:11 Jerome LAPTOP === Setup ended ===
2013/3/2:09:24:20 Jerome LAPTOP === Setup started on LAPTOP by Jerome ===
2013/3/2:09:24:20 Jerome LAPTOP Launch
2013/3/2:09:24:25 Jerome LAPTOP === Setup ended ===
2013/3/2:09:24:22 Jerome LAPTOP PageOpen LaunchDialog
2013/3/2:09:24:35 Jerome LAPTOP PageOpen LicenseDialog
2013/3/2:09:31:01 Jerome LAPTOP PageOpen ProductInfoDialog
2013/3/2:09:31:17 Jerome LAPTOP PageOpen ProductSelectionDialog2
2013/3/2:09:31:19 Jerome LAPTOP PageOpen FullProgressDialog
2013/3/2:09:31:19 Jerome LAPTOP Installing DirectX Runtime: C:\Autodesk\AutoCAD_2012_English_Win_64bit\3rdParty\DirectX\DXSETUP.exe /silent
2013/3/2:09:31:44 Jerome LAPTOP Install DirectX Runtime Succeeded
2013/3/2:09:31:44 Jerome LAPTOP Installing FaroSDK: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/3/2:09:31:52 Jerome LAPTOP Install FaroSDK Succeeded
2013/3/2:09:31:52 Jerome LAPTOP Installing Autodesk Material Library 2012: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/3/2:09:32:11 Jerome LAPTOP Install Autodesk Material Library 2012 Succeeded
2013/3/2:09:32:11 Jerome LAPTOP Installing Autodesk Material Library 2012 - Low Resolution: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/3/2:09:32:32 Jerome LAPTOP Install Autodesk Material Library 2012 - Low Resolution Succeeded
2013/3/2:09:32:32 Jerome LAPTOP Installing Autodesk Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/3/2:09:32:46 Jerome LAPTOP Install Autodesk Content Service Succeeded
2013/3/2:09:32:46 Jerome LAPTOP Installing AutoCAD® 2012: TRANSFORMS="C:\Autodesk\AutoCAD_2012_English_Win_64bit\x64\en-us\acad\acad.mst;C:\Users\Jerome\AppData\Local\Temp\_AI2750.tmp\x64\acad\acad-standalone.mst" MSINEWINSTANCE=1 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2012 - English\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/3/2:09:33:18 Jerome LAPTOP Install AutoCAD® 2012 Failed Installation aborted, Result=1603
2013/3/2:09:33:22 Jerome LAPTOP Rollback Autodesk Content Service Succeeded
2013/3/2:09:33:37 Jerome LAPTOP Rollback Autodesk Material Library 2012 - Low Resolution Succeeded
2013/3/2:09:33:55 Jerome LAPTOP Rollback Autodesk Material Library 2012 Succeeded
2013/3/2:09:33:56 Jerome LAPTOP Rollback FaroSDK Succeeded
2013/3/2:09:33:56 Jerome LAPTOP Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2013/3/2:09:33:56 Jerome LAPTOP PageOpen InstallCompleteDialog
2013/3/2:09:34:00 Jerome LAPTOP === Setup ended ===
2013/3/2:11:38:17 Jerome LAPTOP === Setup started on LAPTOP by Jerome ===
2013/3/2:11:38:17 Jerome LAPTOP Launch
2013/3/2:11:38:31 Jerome LAPTOP === Setup ended ===
2013/3/2:11:38:23 Jerome LAPTOP PageOpen LaunchDialog
2013/3/2:11:39:22 Jerome LAPTOP PageOpen LicenseDialog
2013/3/2:11:39:43 Jerome LAPTOP PageOpen ProductInfoDialog
2013/3/2:11:40:07 Jerome LAPTOP PageOpen ProductSelectionDialog2
2013/3/2:11:40:54 Jerome LAPTOP PageOpen FullProgressDialog
2013/3/2:11:40:54 Jerome LAPTOP Installing Microsoft Visual C++ 2010 Redistributable (x86): C:\Autodesk\AutoCAD_2012_English_Win_64bit\3rdParty\x86\VCRedist\2010\vcredist_x86.exe /q /l C:\Users\Jerome\AppData\Local\Temp\vcredist_x86_2010.log
2013/3/2:11:41:01 Jerome LAPTOP Install Microsoft Visual C++ 2010 Redistributable (x86) Succeeded
2013/3/2:11:41:01 Jerome LAPTOP Installing Autodesk® Design Review: TRANSFORMS="C:\Users\Jerome\AppData\Local\Temp\_AID4AE.tmp\x86\en-us\Components\adr2012\SetupDesignReview2012-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" INSTALLDIR="C:\Program Files (x86)\Autodesk\Autodesk Design Review 2012\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/3/2:11:41:10 Jerome LAPTOP Install Autodesk® Design Review Failed Failure is ignored, Result=1603
2013/3/2:11:41:10 Jerome LAPTOP Installing DirectX Runtime: C:\Autodesk\AutoCAD_2012_English_Win_64bit\3rdParty\DirectX\DXSETUP.exe /silent
2013/3/2:11:42:06 Jerome LAPTOP Install DirectX Runtime Succeeded
2013/3/2:11:42:06 Jerome LAPTOP Installing FaroSDK: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/3/2:11:42:19 Jerome LAPTOP Install FaroSDK Succeeded
2013/3/2:11:42:19 Jerome LAPTOP Installing Autodesk Material Library 2012: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/3/2:11:42:44 Jerome LAPTOP Install Autodesk Material Library 2012 Succeeded
2013/3/2:11:42:44 Jerome LAPTOP Installing Autodesk Material Library 2012 - Low Resolution: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/3/2:11:43:27 Jerome LAPTOP Install Autodesk Material Library 2012 - Low Resolution Succeeded
2013/3/2:11:43:27 Jerome LAPTOP Installing Autodesk Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/3/2:11:43:43 Jerome LAPTOP Install Autodesk Content Service Succeeded
2013/3/2:11:43:45 Jerome LAPTOP Installing AutoCAD® 2012: TRANSFORMS="C:\Autodesk\AutoCAD_2012_English_Win_64bit\x64\en-us\acad\acad.mst;C:\Users\Jerome\AppData\Local\Temp\_AID4AE.tmp\x64\acad\acad-standalone.mst" MSINEWINSTANCE=1 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2012 - English\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/3/2:11:43:50 Jerome LAPTOP Install AutoCAD® 2012 Failed Installation aborted, Result=1603
2013/3/2:11:44:03 Jerome LAPTOP Rollback Autodesk Content Service Succeeded
2013/3/2:11:44:21 Jerome LAPTOP Rollback Autodesk Material Library 2012 - Low Resolution Succeeded
2013/3/2:11:44:43 Jerome LAPTOP Rollback Autodesk Material Library 2012 Succeeded
2013/3/2:11:44:44 Jerome LAPTOP Rollback FaroSDK Succeeded
2013/3/2:11:44:44 Jerome LAPTOP Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2013/3/2:11:44:44 Jerome LAPTOP Rollback Microsoft Visual C++ 2010 Redistributable (x86) Failed Installation aborted, Result=1619
3 REPLIES 3
jholasca
in reply to: jholasca
Anybody encoutered this kind of error before?
TravisNave
The 1603 error is very vague.  What OS are you instaling onto and do you have any other flavor or AutoCAD already installed or previously installed?
See my 1603 link in my hot signature line for additional info.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
jholasca
in reply to: TravisNave
I have windows 7 64 bit and have no other autocad flavors installed or previously installed. this is the first time that I install autocad software on this computer.
Administrator Productivity
