Installation & Licensing
New Member
Ali_mohamed
Message 1 of 4 (4,202 Views)
Tried Maya 2012 (657D1 2012.0.0.F), error 20 ,Please help
4202 Views, 3 Replies
12-11-2011 01:46 AM
Dears,
I am having a strange problem in running Maya.
License was installed correctly
Deployment was created also but when we run Maya from the clients it refuses to obtain a license and the error is below:
License was not obtained
License method:
environment variable MAYA_LICENSE_METHOD='network'
Product choice:
environment variable MAYA_LICENSE='unlimited'
License file override:
environment variable MAYA_ALT_EN is not set
Product Support
Message 2 of 4 (4,178 Views)
Re: Tried Maya 2012 (657D1 2012.0.0.F), error 20 ,Please help
12-12-2011 12:42 PM in reply to: Ali_mohamed
Look for the C:\flexlm\maya.lic file.  Edit the file using Notepad and edit the license file as necessary.  Typically, it will look like:
SERVER servername 0
USE_SERVER
Alternate file can be:
SERVER ip-address-of-server 0
USE_SERVER
David Lau
Active Member
johnnythaitran
Message 3 of 4 (3,845 Views)
01-28-2012 12:40 AM in reply to: Ali_mohamed
I have the exact same problem and I get the exact same message. I have tried to uninstall and reinstalled, but failed. I have even tried to install Maya 2011, but I still get the same error.
Interesting note: I have the same product key as you for Maya 2012, 657D1. I think MAYBE Autodesk is sending out corrupt product trials for students and that's why these installs aren't working.
P.S. I tried to install AutoCad for Mac and I got the same error, it won't boot up. My product key is 777D1. Would you by any chance be having the same problem?
Johnny
Johnnythaitran@gmail.com
New Member
Message 4 of 4 (1,668 Views)
02-12-2013 07:23 PM in reply to: Ali_mohamed
I am running Maya 2012 Hotfix 4 on Mac OS X 10.6.8.
I am having a similar problem, but with a standalone licesnse for Maya Unlimited.
License method:
environment variable MAYA_LICENSE_METHOD='standalone'
Product choice:
Maya used to work fine, but this problem suddenly began happening. Any help would be greatly appreciated.
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Connect with Us
Twitter
Pinterest
Blog
Youtube
