Installation & Licensing
Stand-alone to Network 2010 (R18.0)
13 REPLIES 13
Message 1 of 14
TravisNave
3718 Views, 13 Replies
Autodesk finally changed the method of converting AutoCAD from stand-alone to network in the registry with AutoCAD 2010 products. No longer is there a 2a=stand-alone and 19=network. Now it is simply 1=network 2=stand-alone.
Location is still the same as before:
HKLM \ Software \ Autodesk \ AutoCAD \ R18.0 \ ACAD-8001:409 \ AdLM
Type REG_DWORD Value 1=network 2=stand-alone
Also, the adskflex.exe NLM version is 11.5 this time around.
Enjoy!
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
13 REPLIES 13
Message 2 of 14
in reply to: TravisNave
Thanks for the report.
You cannot go from NLM to Standalone though without a reinstall, right?
R.K. McSwain
http://cadpanacea.com
Message 3 of 14
TravisNave
According to my initial tests, this appears to be correct. If I find a work-around, I will let you know. However, it would probably be dependent on installing with 000-00000000 and 00000 during initial setup. Network keys will not authorize as stand-alone.
Autodesk Forums:
Message 4 of 14
TravisNave
It appears that I cannot get the product to launch after making the switch. I will have to determine the root cause.
Autodesk Forums:
Message 5 of 14
That is what I thought. Is this just an oversight or are they purposely
trying to discourage changing this? Why isn't a switch in either
direction made easier? ....
R.K. McSwain
Message 6 of 14
TravisNave
I would have to think that they are trying to discourage it. My initial testing on this has been unsuccessful, so I will have to spend more time searching for a workable solution. It's unfortunate, because such a simple switch does help in many situations.
Autodesk Forums:
Message 7 of 14
cdodge
It's possible (but kinda ugly) to switch from standalone to network....
1) Set the TYPE registry key to "1" (3=Standalone) in the following registry location:
HKEY_LOCAL_MACHINE\Software\Autodesk\AutoCAD\R18.0\ACAD-XXXX:409\ADLM
If you were to start AutoCAD now, it would flash something on screen then exit VERY quickly.
2) This is the hard bit: Find someone's machine that has ALL of the same 2010 products installed with network licensing.
3) Take a copy of the following file from the other persons machine and put it in the same location on yours:
C:\Program Files\Autodesk Product\LICPATH.LIC
Note: Unlike past versions of the product, 2010 seems to require this file EVEN if the "ADSKFLEX_LICENSE_FILE" registry setting or environment variable is set correct.
4) Backup the following file on your machine, then copy over it with the same file from the other persons machine:
XP: C:\Documents and settings\All Users\Application Data\Autodesk\ADLM\ProductInformation.PIT
Vista: C:\ProgramData\Autodesk\ADLM\ProductInformation.PIT
Important notes: The PIT (Product Information Table) is an encrypted file that that has a table of information about every 2010 network or standalone product you have installed. So if you could magically decrypt it, its contents would look very roughly like the following:
AUTOCAD 2010, NETWORK
AUTOCAD ARCHITECTURE 2010, NETWORK
AUTOCAD MAP 3D 2010, NETWORK
AUTOCAD LT 2010, STANDALONE
So you can see how important it is to replace the file with one from a machine that has all of the same products.
The network version of that file IS transferable from machine to machine but I do not know for sure if standalone versions are 100% transferable in the same way.
The LOG file(s) in the same location as the PIT file can help you troubleshoot some issues - For example, I had a customer who log file said "Error reading decrypted information". It turns out that was due to the BETA version of AutoCAD being on the machine beforehand. And even though he cleaned up using the Autodesk supplied AcRegClean utility, it did not remove ProductInformation.PIT. Uninstalling/reinstalling after removing that file did the trick.
And keep in mind that if you do a REPAIR, REINSTALL or SERVICE PACK install that the registry key on step 1 will revert back to 3. I have verified that a repair or reinstall do NOT overwrite ProductInformation.PIT, so you shouldn't have to copy that file in again.
They should rename PIT to PITA
Chris Dodge
Microdesk
Message 8 of 14
TravisNave
Excellent find! I will try this also.
Autodesk Forums:
Message 9 of 14
TravisNave
Hmmm, corruption of this PIT file could mean imminent disaster for all Autodesk installed products. This change worries me a bit. However, I did verify your findings. It would be nice if we could find a way to modify this file...
Autodesk Forums:
Message 10 of 14
cdodge
I agree.
A good example: After I *thought* I removed all the 2010 beta products from my machine, I deleted that ADLM folder.
However, I missed MAP 2010 beta.
When I found it and tried to uninstall it the uninstall failed with an error that it was not able to update the registration information. (I never did test to see if a repair install would have added the map info back to the PIT file...)
I was forced to use msizap and a manual cleanup of 100's of locations to get rid of map. And I'm sure I didnt find everything.
But the possibility of ProductInformation.PIT corruption or missing products are very good reasons why at the very least there should be a separate PITA file for each application installed. Or give the installer the ability to ignore the failure when adding or removing products from the file.
Message 11 of 14
TravisNave
Exactly. So now if the file is corrupt or missing, it takes a perfectly good working installation and keeps it from launching. Real smart.
Autodesk Forums:
Message 12 of 14
TravisNave
From what I understand now, this ProductInformation.PIT is the replacement for 2010 PLIST that is hard coded and provides the cascading information. PLIST itself is now only for legacy products.
Autodesk Forums:
Message 13 of 14
mwaychoff
returning to this old topic...
has anyone determined if you have a PIT from a CPU that perhaps had more apps on it than a normal user would the presence of additional info in the PIT cause a problem on the CPU with fewer apps? if not perhaps someone could build a kickin' box and submit an all inclusive PIT for CAD Mgr.s
Message 14 of 14
TravisNave
I would love to try this. Perhaps I will when I get some time to play with the product line. Probably won't happen until the 2011 product is released... and they'll probably change the workings by then. 🙂
Autodesk Forums:
Administrator Productivity
