Installation & Licensing
New Member
Message 1 of 10 (105 Views)
Shadow Licenses Servers are not working in redundatn ADLM instalation
105 Views, 9 Replies
08-04-2000 07:55 AM
I hava 3 Redundant ADLM Licenses Servers installed on NT 4.0
but my clients only connect to the Master Server.
Shadows servers never are used by clients, even when I point the
ACADSERVER environment variable from each client to a shaw server
This seems like my redundant servers are not working as redundant servers
because only one (the master) license server is working like a standalone.
How Can I distribute licenses from shadow servers to my ACAD2000 clients?
*Schroeder, Bud
Message 2 of 10 (105 Views)
Re: Shadow Licenses Servers are not working in redundatn ADLM instalation
08-05-2000 11:11 AM in reply to: jsosai
I think there is some confusion on what and how redundant servers do. For
example. You have 3 servers in your pool. Master, Shadow, Shadow. All
three servers are setup to license the same amount of AutoCAD's and or
vertical products. So the master is the one that is actually dishing out the
licenses here. Now if your Master server goes down, the next shadow server in
the list will move to Master and be handing out the license. The idea is that
you always have a server running the license manager. It's not distributed
services in the sense that you can put different groups on different servers.
Your best bet for that is to have more than one server and point your groups
to them.
Hope this helps clear this up.
Bud
*iglesias, jesus sosa
Message 3 of 10 (105 Views)
Re:
08-07-2000 08:55 AM in reply to: jsosai
Bud:
Ok , Is good to know how the redundant license server works.
but then now I change my question to the next:
How I can make my Shadow Servers become a master server?
thats is because always when I shutdown my Master Server
my Acad200 Clients Can´t get Licenses from the Shadow Servers...
Bud Schroeder wrote:
> Hello,
> to them.
> Bud
*milana, jerry
Message 4 of 10 (105 Views)
Re:
08-07-2000 11:16 AM in reply to: jsosai
Are all of your redundant servers on the same subnet?
Are your workstations in subnets remote from your AdLM servers?
How are you setting the ACADSERVER variable? Does the "@" symbol appear in
the variable value? Note: If using redundant servers, the @ symbol should
NEVER be used with ACADSERVER.
What operating system are you using for your redundant servers?
Jerry Milana,
Autodesk Product Support
"jesus sosa iglesias" wrote in message
news:398EDC02.FF77CED3@imp.mx...
> Bud:
> > Hello,
For
All
out the
server in
is that
distributed
servers.
groups
> > to them.
> > Bud
servers
standalone.
clients?
Message 5 of 10 (105 Views)
Re:
08-07-2000 02:25 PM in reply to: jsosai
Jerry
I installed all of my redundant Licenses Servers on NT version 4.0 Intel
All of them are on the same network (192.168.143.0).
Some of my clients are on the same network but others are in others local
networks.
my Autocad clients are using Win95/98/NT 4.0
andMy ACADSERVER Environment variable for each of my clients
is:
set ACADSERVER=192.168.143.225;192.168.143.242;192.168.143.245
jerry milana wrote:
> Hi,
> Jerry Milana,
> > Bud:
> > > Hello,
> For
> All
> out the
> server in
> is that
> distributed
> servers.
> groups
> > > to them.
> > > Bud
> servers
> standalone.
> clients?
Message 6 of 10 (105 Views)
Re:
08-07-2000 03:25 PM in reply to: jsosai
My Fault
I forgot to register AUTH CODE in one of my redundant servers
Everything works fine now!
jesus sosa iglesias wrote:
> Bud:
> > Hello,
> > to them.
> > Bud
*milana, jerry
Message 7 of 10 (105 Views)
Re:
Jesus,
ACADSERVER should not be set to IP addresses, it should be set to hostnames.
All systems must be able to ping the server by hostname and the server must
be able to ping the workstations by hostnames. Even though you got things
running, you should fix this as you may have problems down the road.
jerry
news:398F3741.56CE326D@imp.mx...
> My Fault
> Thanks
> > Bud:
> > > Hello,
For
All
out the
server in
is that
distributed
servers.
groups
> > > to them.
> > > Bud
servers
standalone.
clients?
*Schroeder, Bud
Message 8 of 10 (105 Views)
Re:
08-07-2000 09:41 PM in reply to: jsosai
I see you have been going back and forth with Jerry. I did not see these messages
from the office today;-). You should also change to your host name, and not use the
IP addresses as Jerry had suggested. It will save you some headaches down the road.
Thanks for letting us know you are up and running.
Bud
> My Fault
> Thanks
> > Bud:
> > > Hello,
> > > to them.
> > > Bud
*Frampton, John
Message 9 of 10 (105 Views)
Re:
08-08-2000 06:21 AM in reply to: jsosai
Jerry,
I understand that the workstations need to be able to ping the server by
hostname, but I am unsure why the server would need to be able to ping the
workstations by hostname. My current setup is; the Server has a static IP
address, is in the DNS server, and on segment 120: some of my clients have
static IP's but are not in the DNS server, on segments 122 & 123(segment
doesn't have a DHCP server: other clients are running DHCp and on segments
120 &121. The Acadserver variable is currently set to SERVERNAME
(ACADSERVER=SERVERname). We don't use local host files. Everything is and
has been up and running fine. Could you please explain this better, so I
can talk to my networking people about a resolution? And advise how things
should work in an enviroment using DHCP? What are some of the problems I
may see that you mention? I currently don't have a shadowserver but am
looking into installing one on the same segment (120) as the current ADLM.
As always Thanks,
John A. Frampton.
"jerry milana" wrote in message
news:ef320af.5@WebX.SaUCah8kaAW...
> Jesus,
hostnames.
must
> jerry
> > My Fault
> > Thanks
> > > Bud:
> > > > Hello,
do.
> For
> All
or
dishing
> out the
> server in
idea
> is that
> distributed
> servers.
your
> groups
> > > > to them.
> > > > Bud
> servers
> standalone.
> clients?
*milana, jerry
Message 10 of 10 (105 Views)
Re:
08-08-2000 02:22 PM in reply to: jsosai
John,
AdLM authenticates against hostnames, if you do not have name resolution
enabled in both directions, you may get failures of one or more workstations
in obtaining licenses.
jerry
"John Frampton" wrote in message
news:ef320af.7@WebX.SaUCah8kaAW...
> Jerry,
by
and
things
> As always Thanks,
> John A. Frampton.
> > Jesus,
> hostnames.
> must
things
> > jerry
> > > My Fault
> > > Thanks
> > > > Bud:
> > > > > Hello,
> do.
> > For
Shadow.
> > All
and
> or
> dishing
> > out the
shadow
> > server in
> idea
> > is that
> > distributed
different
> > servers.
> your
> > groups
> > > > > to them.
> > > > > Bud
server
redundant
> > servers
> > standalone.
> > clients?
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Connect with Us
Twitter
Pinterest
Blog
Youtube
