Installation & Licensing
Service Pack and Previous Hotfixes
7 REPLIES 7
Message 1 of 8
Lineabove
469 Views, 7 Replies
When you install a Service Pack (ie: SP 1), does the Service Pack include all the previous hotfixes which are listed on the website?
7 REPLIES 7
Message 2 of 8
aaronhai
in reply to: Lineabove
Which product are you enquiring for, as aswers may vary depending on the product.
Aaron Hai
Message 3 of 8
Lineabove
in reply to: aaronhai
Hi Aaron,
Product is the Autodesk Revit Architecture Suite 2013.
I have reinstalled over this past weekend and updated to the Sevice Packs available on the Autodesk website when reinstalling.
Is there a need to install any of the previous hotfixes?
Message 4 of 8
Lineabove
Noticed tonight when applying an update via Live Update, there is a explanatory note that the update includes all previous fixes.
(Usually I have downloaded the Service Pack directly and then installed.)
Message 5 of 8
RandMan
How can we tell that the Hotfix was installed properly?  I recently installed The Revit MEP update 2, then the recent Hotfix.  My build number is listed as 20121003_2115(x64).  How can I tell if I installed the Hotfix correctly?  Since it was not self-extracting, I may have missed something.  I'm crashing, just opening a 3D view now.  Very unstable!  My video card rates a 6.9.  My resource monitor shows I'm only using 23% of memory when Revit disappears.
Message 6 of 8
TravisNave
in reply to: RandMan
It's quite possible that you need to update your video card driver.  What is your card, OS, and driver version?
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Message 7 of 8
RandMan
in reply to: TravisNave
Video Card is a NVIDA GeForce 8800 GTX with driver 9.18.13.697
The machine is a Win 7, 64 bit
I suspect you are asking for the OS of the card itself, and I have the 32 bit driver, rather than the 64.  I'll gather more info, but I think you're on the right track.  Thanks.
Message 8 of 8
TravisNave
Yeah.  You might try a clean installation of this latest WHQL driver for that card:
http://www.nvidia.com/object/win8-win7-winvista-64bit-314.07-whql-driver.html
Hope it helps.
Autodesk Forums:
Administrator Productivity
