We did not receive a serial number with either the download from the Subscription Center or with the discs which were sent. How do we get a serial number so we can use AutoCAD 2011?
Thank you,
Ed O'Connor
Solved by TravisNave. Go to Solution.
It is available to the CAD Manager's Subscription account online at http://subscription.autodesk.com. You can also get this information from your value-added reseller, if you have one.
We moved your post to a new topic where there is likely to be more active feedback on the topic.
I did not receive a serial number with either the download from the Subscription Center or with the discs which were sent. How do we get a serial number so we can use AutoCAD 2012? Please help me.. thanks.
