Installation & Licensing
5925 Views, 6 Replies
SDI System Variable
How can I set up the "multiple-drawing interface"? When I type "SDI" it has
3 as a default value. It doesn't allow me to change it to 0. What can I do?
6 REPLIES 6
What version of AutoCAD are you using? AFAIK, 3 has never been a legal value
for SDI ... only 0 and 1.
___
"Juan Lopez" wrote in message
news:24FAB16063C19A36C7CA7632D5F30DAA@in.WebX.maYIadrTaRb...
has
do?
I'm using LDD3.
"Paul Turvill" wrote in message
news:1A398A632BDCCC6649FCD4BE9C0BBBE1@in.WebX.maYIadrTaRb...
value
> ___
> has
> do?
3 is a "legal" value as well as 2. But you can't manually set those values.
This is from the help file:
0 Turns on multiple-drawing interface.
1 Turns off multiple-drawing interface.
2 (Read-only) Multiple-drawing interface is disabled because AutoCAD has
loaded an application that does not support multiple drawings. SDI setting 2
is not saved.
3 (Read-only) Multiple-drawing interface is disabled because the user has
set SDI to 1 and AutoCAD has loaded an application that does not support
multiple drawings. (SDI was set to 1 before the application was loaded.) SDI
setting 3 is not saved.
If SDI is set to 3, AutoCAD switches it back to 1 when the application
that doesn't support multiple drawings is unloaded.
Juan,
Do you have any 3rd party add-ons? Or anything else loaded that is not
loaded from your base install of LDD3? If not, then it is LDD3 causing
this.
Kevin Nehls
news:9E027D50386643AE85455D519BD37FCC@in.WebX.maYIadrTaRb...
> I'm using LDD3.
I would suspect that CADOverlay has been loaded.It turns (at least 200oi and
if I remember correct, 2002) SDI on.
/Petri
"Kevin Nehls" wrote in message
news:A57A3C096F13E46C8DCE6D915682775D@in.WebX.maYIadrTaRb...
values.
2
> is not saved.
SDI
> Juan,
> this.
> Kevin Nehls
> > I'm using LDD3.
If that is the case they may want to look into the latest version of CAD
Overlay, now called "Raster Design", that probably (read: hopefully) doesn't
do this. www.autodesk.com/rasterdesign I don't know if it is MDI aware or
not since I don't use that software.
There are other 3rd party add-ons that do this as well.
Kevin Nehls
"Petri Ahava" wrote in message
news:D74C2B0A6B762DC13BB99DD5611C9542@in.WebX.maYIadrTaRb...
> Hi,
and
> /Petri
checked it and RD 3 indeed does not revert to SDI any longer. Then again it
might be an LDD3 addon (all the nice Civil Design packages inherited from
Softdesk...)
/Petri
news:0349F88AF2E888700AA1D7C743BDA0DA@in.WebX.maYIadrTaRb...
doesn't
> Kevin Nehls
> > Hi,
> and
> > /Petri
Administrator Productivity
