I am trying out LT before buying. I can not begin the Part 2 'Creating Walls' exercise as I can't open the tutorial file. I can download it, but when it opens, it does NOT have the letters and numbers on the plan sheet to follow.
Are you able to try to repair and reinstall the program?
Go here: Start > Control Panel > Programs & Features > Revit LT > Reinstall.
No. I installed the Revit LT 30 day trial yesterday. Got through the first tutorial session (Creating a project/adding levels), and want to go to the next session. Tried to open the file that is listed, and nothing happened. Then I saved the file andtired to open it. Nothing. Tried again (download and open), and the file did open, but the numbered/letter sequences that are to be on the Foundation plan are not there.
David: When I go throught eh sequence you outlined above, I only get the 'Uninstall/Change' tab. No Reinstall or Repair.
Thank you.
No. If I click 'Uninstall/Change', the only message that comes up is to confirm removing Revit LT.
I don't know how to do a screen capture. Also, what screen would you want to capture?
I think that I will uninstall Revit LT, and then reinstall it to see if that makes any difference. There might have been some issue in the downloading, unpackaging, and installing, even though I have cable internet service.
I am having the same issue. The project file GSG_02_create_walls.rvt does not contain the markers for wall boundries.
I downloaded the GSG_02_complete - and it has them but it is also _ complete. Was this discussion thread ever resolved? Thank you.
