Installation & Licensing
New Member
Message 1 of 3 (431 Views)
Revit Architecture 2013 Installation Issues
431 Views, 2 Replies
03-02-2013 12:15 AM
I've tried to install Revit a few times now, and after a long process it fails in the end.  I am getting this:
2013/3/1:19:32:39 Andrew ANDREW-HP === Setup started on ANDREW-HP by Andrew === 2013/3/1:19:32:39 Andrew ANDREW-HP Launch 2013/3/1:19:32:43 Andrew ANDREW-HP [Error: 1056] An instance of the service is already running. 2013/3/1:19:32:43 Andrew ANDREW-HP === Setup ended ===
2013/3/1:19:32:38 Andrew ANDREW-HP === Setup started on ANDREW-HP by Andrew === 2013/3/1:19:32:38 Andrew ANDREW-HP Launch 2013/3/1:19:32:38 Andrew ANDREW-HP CommandLine    2013/3/1:19:32:43 Andrew ANDREW-HP === Setup ended ===
2013/3/1:19:43:17 Andrew ANDREW-HP === Setup started on ANDREW-HP by Andrew === 2013/3/1:19:43:17 Andrew ANDREW-HP Launch 2013/3/1:19:43:17 Andrew ANDREW-HP CommandLine /url "http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/Autodesk_Revit_2013_English_Win_32_64bit_w..." /SN 900-35525242 /PK 829E1 /student /skipEULA /akamai /auth  /sid   2013/3/1:19:51:23 Andrew ANDREW-HP === Setup ended ===
2013/3/1:19:43:19 Andrew ANDREW-HP === Setup started on ANDREW-HP by Andrew === 2013/3/1:19:43:19 Andrew ANDREW-HP Launch 2013/3/1:19:46:47 Andrew ANDREW-HP Download Play SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/SET... 2013/3/1:19:51:23 Andrew ANDREW-HP Download Complete SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/SET... 2013/3/1:19:51:23 Andrew ANDREW-HP PageOpen LaunchDialog   2013/3/1:19:56:09 Andrew ANDREW-HP PageOpen LicenseDialog   2013/3/1:19:56:09 Andrew ANDREW-HP PageOpen ProductInfoDialog   2013/3/1:19:56:09 Andrew ANDREW-HP PageOpen ProductSelectionDialog2   2013/3/1:19:56:55 Andrew ANDREW-HP PageOpen FullProgressDialog   2013/3/1:19:56:56 Andrew ANDREW-HP Download Play VCREDIST2010SP1X86 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/VCR... 2013/3/1:19:58:22 Andrew ANDREW-HP Download Complete VCREDIST2010SP1X86 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/VCR... 2013/3/1:19:58:22 Andrew ANDREW-HP Installing Microsoft Visual C++ 2010 SP1 Redistributable (x86): C:\Autodesk\WI\Autodesk Revit 2013\3rdParty\x86\VCRedist\2010SP1\vcredist_x86.exe /q /norestart 2013/3/1:19:58:37 Andrew ANDREW-HP Install Microsoft Visual C++ 2010 SP1 Redistributable (x86) Succeeded  2013/3/1:19:58:39 Andrew ANDREW-HP Download Play VCREDIST2010SP1X64 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/VCR... 2013/3/1:19:59:45 Andrew ANDREW-HP Download Complete VCREDIST2010SP1X64 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/VCR... 2013/3/1:19:59:45 Andrew ANDREW-HP Installing Microsoft Visual C++ 2010 SP1 Redistributable (x64): C:\Autodesk\WI\Autodesk Revit 2013\3rdParty\x64\VCRedist\2010SP1\vcredist_x64.exe /q /norestart 2013/3/1:19:59:57 Andrew ANDREW-HP Install Microsoft Visual C++ 2010 SP1 Redistributable (x64) Succeeded  2013/3/1:19:59:57 Andrew ANDREW-HP Download Play KB958314ATLX86 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/KB9... 2013/3/1:19:59:58 Andrew ANDREW-HP Download Complete KB958314ATLX86 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/KB9... 2013/3/1:19:59:58 Andrew ANDREW-HP Installing Microsoft Visual C++ 2008 KB958314 (ATL) (x86):   ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/3/1:20:00:03 Andrew ANDREW-HP Install Microsoft Visual C++ 2008 KB958314 (ATL) (x86) Succeeded  2013/3/1:20:00:03 Andrew ANDREW-HP Download Play KB958314MFCX86 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/KB9... 2013/3/1:20:02:09 Andrew ANDREW-HP Download Complete KB958314MFCX86 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/KB9... 2013/3/1:20:02:09 Andrew ANDREW-HP Installing Microsoft Visual C++ 2008 KB958314 (MFC) (x86):   ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/3/1:20:02:16 Andrew ANDREW-HP Install Microsoft Visual C++ 2008 KB958314 (MFC) (x86) Succeeded  2013/3/1:20:02:17 Andrew ANDREW-HP Download Play KB958314CRTX86 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/KB9... 2013/3/1:20:02:32 Andrew ANDREW-HP Download Complete KB958314CRTX86 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/KB9... 2013/3/1:20:02:32 Andrew ANDREW-HP Installing Microsoft Visual C++ 2008 KB958314 (CRT) (x86):   ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/3/1:20:02:38 Andrew ANDREW-HP Install Microsoft Visual C++ 2008 KB958314 (CRT) (x86) Succeeded  2013/3/1:20:02:38 Andrew ANDREW-HP Download Play KB958314OPENMPX86 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/KB9... 2013/3/1:20:02:40 Andrew ANDREW-HP Download Complete KB958314OPENMPX86 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/KB9... 2013/3/1:20:02:40 Andrew ANDREW-HP Installing Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86):   ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/3/1:20:02:45 Andrew ANDREW-HP Install Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86) Succeeded  2013/3/1:20:02:46 Andrew ANDREW-HP Download Play KB958314ATLX64 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/KB9... 2013/3/1:20:02:47 Andrew ANDREW-HP Download Complete KB958314ATLX64 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/KB9... 2013/3/1:20:02:47 Andrew ANDREW-HP Installing Microsoft Visual C++ 2008 KB958314 (ATL) (x64):   ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/3/1:20:02:50 Andrew ANDREW-HP Install Microsoft Visual C++ 2008 KB958314 (ATL) (x64) Succeeded  2013/3/1:20:02:50 Andrew ANDREW-HP Download Play KB958314MFCX64 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/KB9... 2013/3/1:20:04:50 Andrew ANDREW-HP Download Complete KB958314MFCX64 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/KB9... 2013/3/1:20:04:50 Andrew ANDREW-HP Installing Microsoft Visual C++ 2008 KB958314 (MFC) (x64):   ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/3/1:20:04:57 Andrew ANDREW-HP Install Microsoft Visual C++ 2008 KB958314 (MFC) (x64) Succeeded  2013/3/1:20:04:57 Andrew ANDREW-HP Download Play KB958314CRTX64 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/KB9... 2013/3/1:20:05:13 Andrew ANDREW-HP Download Complete KB958314CRTX64 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/KB9... 2013/3/1:20:05:13 Andrew ANDREW-HP Installing Microsoft Visual C++ 2008 KB958314 (CRT) (x64):   ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/3/1:20:05:19 Andrew ANDREW-HP Install Microsoft Visual C++ 2008 KB958314 (CRT) (x64) Succeeded  2013/3/1:20:05:20 Andrew ANDREW-HP Download Play KB958314OPENMPX64 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/KB9... 2013/3/1:20:05:21 Andrew ANDREW-HP Download Complete KB958314OPENMPX64 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/KB9... 2013/3/1:20:05:21 Andrew ANDREW-HP Installing Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64):   ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/3/1:20:05:26 Andrew ANDREW-HP Install Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64) Succeeded  2013/3/1:20:05:26 Andrew ANDREW-HP Download Play VCREDIST2005SP1ATLX86 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/VCR... 2013/3/1:20:06:12 Andrew ANDREW-HP Download Complete VCREDIST2005SP1ATLX86 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/VCR... 2013/3/1:20:06:12 Andrew ANDREW-HP Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): C:\Autodesk\WI\Autodesk Revit 2013\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Andrew\AppData\Local\Temp\vcredist_x86_2005.log"" " 2013/3/1:20:06:34 Andrew ANDREW-HP Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Succeeded  2013/3/1:20:06:34 Andrew ANDREW-HP Download Play VCREDIST2005SP1ATLX64 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/VCR... 2013/3/1:20:07:20 Andrew ANDREW-HP Download Complete VCREDIST2005SP1ATLX64 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/VCR... 2013/3/1:20:07:20 Andrew ANDREW-HP Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64): C:\Autodesk\WI\Autodesk Revit 2013\3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.exe /q:a /T:C:\Windows\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Andrew\AppData\Local\Temp\vcredist_x64_2005.log"" " 2013/3/1:20:07:37 Andrew ANDREW-HP Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64) Succeeded  2013/3/1:20:07:37 Andrew ANDREW-HP Download Play DIRECTX http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/DIR... 2013/3/1:20:15:55 Andrew ANDREW-HP Download Error DIRECTX <B>File not found</B>Please Install Now again from the Autodesk website.  http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/DIR... 2013/3/1:20:15:56 Andrew ANDREW-HP Download Aborted DIRECTX http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/DIR... 2013/3/1:20:15:56 Andrew ANDREW-HP Install DirectX® Runtime Failed Download Failed, Installation aborted, Result=1603 2013/3/1:20:15:56 Andrew ANDREW-HP Download Play FaroSDK http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/Far... 2013/3/1:20:17:26 Andrew ANDREW-HP Download Error FaroSDK <B>File not found</B>Please Install Now again from the Autodesk website.  http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/Far... 2013/3/1:20:17:26 Andrew ANDREW-HP Download Aborted FaroSDK http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/Far... 2013/3/1:20:17:26 Andrew ANDREW-HP Install FaroSDK Failed Download Failed, Installation aborted, Result=1603 2013/3/1:20:17:27 Andrew ANDREW-HP Download Play RVT2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/RVT... 2013/3/1:20:37:54 Andrew ANDREW-HP Download Error RVT2013 <B>File not found</B>Please Install Now again from the Autodesk website.  http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/RVT... 2013/3/1:20:37:55 Andrew ANDREW-HP Download Aborted RVT2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/RVT... 2013/3/1:20:37:55 Andrew ANDREW-HP Install Autodesk® Revit® 2013 Failed Download Failed, Installation aborted, Result=1603 2013/3/1:20:37:56 Andrew ANDREW-HP Rollback Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64) Failed Installation aborted, Result=1619 2013/3/1:20:37:56 Andrew ANDREW-HP Rollback Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Failed Installation aborted, Result=1619 2013/3/1:20:37:59 Andrew ANDREW-HP Rollback Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64) Succeeded  2013/3/1:20:38:02 Andrew ANDREW-HP Rollback Microsoft Visual C++ 2008 KB958314 (CRT) (x64) Succeeded  2013/3/1:20:38:05 Andrew ANDREW-HP Rollback Microsoft Visual C++ 2008 KB958314 (MFC) (x64) Succeeded  2013/3/1:20:38:07 Andrew ANDREW-HP Rollback Microsoft Visual C++ 2008 KB958314 (ATL) (x64) Succeeded  2013/3/1:20:38:10 Andrew ANDREW-HP Rollback Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86) Succeeded  2013/3/1:20:38:13 Andrew ANDREW-HP Rollback Microsoft Visual C++ 2008 KB958314 (CRT) (x86) Succeeded  2013/3/1:20:38:16 Andrew ANDREW-HP Rollback Microsoft Visual C++ 2008 KB958314 (MFC) (x86) Succeeded  2013/3/1:20:38:18 Andrew ANDREW-HP Rollback Microsoft Visual C++ 2008 KB958314 (ATL) (x86) Succeeded  2013/3/1:20:38:18 Andrew ANDREW-HP Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x64) Failed Installation aborted, Result=1619 2013/3/1:20:38:19 Andrew ANDREW-HP Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x86) Failed Installation aborted, Result=1619 2013/3/1:20:38:19 Andrew ANDREW-HP PageOpen InstallCompleteDialog   2013/3/1:21:00:07 Andrew ANDREW-HP === Setup ended ===
2013/3/1:21:11:29 Andrew ANDREW-HP === Setup started on ANDREW-HP by Andrew === 2013/3/1:21:11:29 Andrew ANDREW-HP Launch 2013/3/1:21:11:29 Andrew ANDREW-HP CommandLine /url "http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/Autodesk_Revit_2013_English_Win_32_64bit_w..." /SN 900-35525242 /PK 829E1 /student /skipEULA /akamai /auth  /sid   2013/3/1:21:11:32 Andrew ANDREW-HP === Setup ended ===
2013/3/1:21:11:31 Andrew ANDREW-HP === Setup started on ANDREW-HP by Andrew === 2013/3/1:21:11:31 Andrew ANDREW-HP Launch 2013/3/1:21:11:32 Andrew ANDREW-HP Download Skipped SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/SET... 2013/3/1:21:11:32 Andrew ANDREW-HP PageOpen LaunchDialog   2013/3/1:21:11:36 Andrew ANDREW-HP PageOpen LicenseDialog   2013/3/1:21:11:36 Andrew ANDREW-HP PageOpen ProductSelectionDialog2   2013/3/1:21:11:53 Andrew ANDREW-HP PageOpen LicenseDialog   2013/3/1:21:11:53 Andrew ANDREW-HP PageOpen LaunchDialog   2013/3/1:21:14:41 Andrew ANDREW-HP PageOpen LicenseDialog   2013/3/1:21:14:41 Andrew ANDREW-HP PageOpen ProductInfoDialog   2013/3/1:21:14:41 Andrew ANDREW-HP PageOpen ProductSelectionDialog2   2013/3/1:21:17:44 Andrew ANDREW-HP PageOpen FullProgressDialog   2013/3/1:21:17:45 Andrew ANDREW-HP Download Play VCREDIST2005X86 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/VCR... 2013/3/1:21:17:52 Andrew ANDREW-HP Download User Pause VCREDIST2005X86 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/VCR... 2013/3/1:21:17:52 Andrew ANDREW-HP Download Paused VCREDIST2005X86 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/VCR... 2013/3/1:21:19:15 Andrew ANDREW-HP Download User Resume VCREDIST2005X86 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/VCR... 2013/3/1:21:19:38 Andrew ANDREW-HP Download Complete VCREDIST2005X86 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/VCR... 2013/3/1:21:19:38 Andrew ANDREW-HP Installing Microsoft Visual C++ 2005 Redistributable (x86): C:\Autodesk\WI\Autodesk Revit 2013\3rdParty\x86\VCRedist\2005\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Andrew\AppData\Local\Temp\vcredist_x86_2005.log"" " 2013/3/1:21:19:49 Andrew ANDREW-HP Install Microsoft Visual C++ 2005 Redistributable (x86) Succeeded  2013/3/1:21:19:49 Andrew ANDREW-HP Download Skipped KB958314ATLX86 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/KB9... 2013/3/1:21:19:49 Andrew ANDREW-HP Installing Microsoft Visual C++ 2008 KB958314 (ATL) (x86):   ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/3/1:21:19:52 Andrew ANDREW-HP Install Microsoft Visual C++ 2008 KB958314 (ATL) (x86) Succeeded  2013/3/1:21:19:53 Andrew ANDREW-HP Download Skipped KB958314MFCX86 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/KB9... 2013/3/1:21:19:53 Andrew ANDREW-HP Installing Microsoft Visual C++ 2008 KB958314 (MFC) (x86):   ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/3/1:21:19:59 Andrew ANDREW-HP Install Microsoft Visual C++ 2008 KB958314 (MFC) (x86) Succeeded  2013/3/1:21:19:59 Andrew ANDREW-HP Download Skipped KB958314CRTX86 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/KB9... 2013/3/1:21:19:59 Andrew ANDREW-HP Installing Microsoft Visual C++ 2008 KB958314 (CRT) (x86):   ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/3/1:21:20:06 Andrew ANDREW-HP Install Microsoft Visual C++ 2008 KB958314 (CRT) (x86) Succeeded  2013/3/1:21:20:07 Andrew ANDREW-HP Download Skipped KB958314OPENMPX86 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/KB9... 2013/3/1:21:20:07 Andrew ANDREW-HP Installing Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86):   ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/3/1:21:20:12 Andrew ANDREW-HP Install Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86) Succeeded  2013/3/1:21:20:13 Andrew ANDREW-HP Download Skipped KB958314ATLX64 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/KB9... 2013/3/1:21:20:13 Andrew ANDREW-HP Installing Microsoft Visual C++ 2008 KB958314 (ATL) (x64):   ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/3/1:21:20:15 Andrew ANDREW-HP Install Microsoft Visual C++ 2008 KB958314 (ATL) (x64) Succeeded  2013/3/1:21:20:16 Andrew ANDREW-HP Download Skipped KB958314MFCX64 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/KB9... 2013/3/1:21:20:16 Andrew ANDREW-HP Installing Microsoft Visual C++ 2008 KB958314 (MFC) (x64):   ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/3/1:21:20:23 Andrew ANDREW-HP Install Microsoft Visual C++ 2008 KB958314 (MFC) (x64) Succeeded  2013/3/1:21:20:24 Andrew ANDREW-HP Download Skipped KB958314CRTX64 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/KB9... 2013/3/1:21:20:24 Andrew ANDREW-HP Installing Microsoft Visual C++ 2008 KB958314 (CRT) (x64):   ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/3/1:21:20:30 Andrew ANDREW-HP Install Microsoft Visual C++ 2008 KB958314 (CRT) (x64) Succeeded  2013/3/1:21:20:30 Andrew ANDREW-HP Download Skipped KB958314OPENMPX64 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/KB9... 2013/3/1:21:20:30 Andrew ANDREW-HP Installing Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64):   ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/3/1:21:20:35 Andrew ANDREW-HP Install Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64) Succeeded  2013/3/1:21:20:36 Andrew ANDREW-HP Download Play DIRECTX http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/DIR... 2013/3/1:21:42:46 Andrew ANDREW-HP Download Error DIRECTX <B>File not found</B>Please Install Now again from the Autodesk website.  http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/DIR... 2013/3/1:21:42:46 Andrew ANDREW-HP Download Error DIRECTX Decompressing failed http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/DIR... 2013/3/1:21:42:46 Andrew ANDREW-HP Download Aborted DIRECTX http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/DIR... 2013/3/1:21:42:46 Andrew ANDREW-HP Install DirectX® Runtime Failed Download Failed, Installation aborted, Result=1603 2013/3/1:21:42:47 Andrew ANDREW-HP Download Play FaroSDK http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/Far... 2013/3/1:21:46:37 Andrew ANDREW-HP Download Complete FaroSDK http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/Far... 2013/3/1:21:46:37 Andrew ANDREW-HP Installing FaroSDK: C:\Autodesk\WI\Autodesk Revit 2013\3rdParty\FaroSDK\e889_faro_ls_sdk_4.8.2.25521_x86_setup.exe /VERYSILENT /NORESTART /LOG="C:\Users\Andrew\AppData\Local\Temp\FaroSDK.log" 2013/3/1:21:47:08 Andrew ANDREW-HP Install FaroSDK Succeeded  2013/3/1:21:47:09 Andrew ANDREW-HP Download Play RVT2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/RVT... 2013/3/1:23:37:37 Andrew ANDREW-HP Download Error RVT2013 <B>File not found</B>Please Install Now again from the Autodesk website.  http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/RVT... 2013/3/1:23:38:06 Andrew ANDREW-HP Download Aborted RVT2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/RVT... 2013/3/1:23:38:06 Andrew ANDREW-HP Install Autodesk® Revit® 2013 Failed Download Failed, Installation aborted, Result=1603 2013/3/1:23:38:06 Andrew ANDREW-HP Rollback FaroSDK Failed Failure is ignored, Result=1619 2013/3/1:23:38:29 Andrew ANDREW-HP Rollback Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64) Succeeded  2013/3/1:23:38:47 Andrew ANDREW-HP Rollback Microsoft Visual C++ 2008 KB958314 (CRT) (x64) Succeeded  2013/3/1:23:39:05 Andrew ANDREW-HP Rollback Microsoft Visual C++ 2008 KB958314 (MFC) (x64) Succeeded  2013/3/1:23:39:16 Andrew ANDREW-HP Rollback Microsoft Visual C++ 2008 KB958314 (ATL) (x64) Succeeded  2013/3/1:23:39:34 Andrew ANDREW-HP Rollback Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86) Succeeded  2013/3/1:23:39:52 Andrew ANDREW-HP Rollback Microsoft Visual C++ 2008 KB958314 (CRT) (x86) Succeeded  2013/3/1:23:40:10 Andrew ANDREW-HP Rollback Microsoft Visual C++ 2008 KB958314 (MFC) (x86) Succeeded  2013/3/1:23:40:23 Andrew ANDREW-HP Rollback Microsoft Visual C++ 2008 KB958314 (ATL) (x86) Succeeded  2013/3/1:23:40:23 Andrew ANDREW-HP Rollback Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1619
Any way to fix this from happening? Any help would be great.
LisaDrago
Message 2 of 3 (344 Views)
Re: Revit Architecture 2013 Installation Issues
03-04-2013 01:10 PM in reply to: agaultney
I have requested your post be moved to the installation discussion group... They may be able to help you more then we can...
LD
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
You can't think AutoCAD and run Revit.
Email: LisaDragoEE@gmail.com
TravisNave
Message 3 of 3 (243 Views)
03-08-2013 06:36 AM in reply to: agaultney
Looks like your download from the student site is aborting.
The download process is very long.  Please make sure you have a steady Internet connection and that it is not dropping or putting your NIC to standby mode when idle for a long period of time.
Travis Nave Send TravisNave a Private Message                       Need help in your post? Mention me with @TravisNave
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Ask the Community
Connect with Us
Twitter
Pinterest
Blog
Youtube
