Well, multiple servers, 1000+ user lan, 20k user wan. Hmmm, that certainly makes things
easy NOT.
Is all (or at least most) of the cad data kept on a single server or is it distributed
amongst them? See if the server guys can spare a junky old 6300 and set it up for a small
group (5-10) of the acad users and see if the problem persists. Try moving the test
server's network connection from the 100bT side to the hub that your small "group" plugs
into.
Check the network cards on the workstation and see if they are set to full duplex
(assuming your hubs will handle that) and have the server guys do the same on the server
(I'd almost bet that they are, but you can never tell).
?guessing?
jason martin
frankfurt-short-bruza
"MMHILL" wrote in message
news:7B0AE6A7337B6EA05E400420A6A76161@in.WebX.maYIadrTaRb...
> Jason,
> Thanks for responding. I tried to answer your questions best that I can.
> If you would like to discuss this via email or phone email me at
> mmhill@southernco.com.
> Thanks,
> michael
> Does the problem happen more often when there are many people connected to
> the server?
> How about when only 1 person is connected to the server?
> We have approximately 1000 people connected to our LAN accessing several
> different application, file and print servers. Our LAN is also connected to
> a rather large WAN of over 20,000.
> Is your network 10bT or 100bT?
> Switched or shared?
> Our LAN is 100bT to the switches. 10bt to the workstations.
> What are the specs on the server?
> Most are Dell 6400 loaded up.
> What network cards are in the machines (clients and servers)?
> Workstaions are Dell with 3com intergrated nics.
> How many users are connected?
> 1000+ ; 150 CAD users
> How much space is taken up on the server?
> Servers are up to 140 gig with up to 95% space utilization.
> What are the file sizes?
> 2D - 250k average. 3-D 1-4 meg.
> If you shutdown the client can someone else then go in and delete the
> original file?
> No immediately. Sometimes I have to get the server dudes to bump the user.
> How about if you disconnect the client from the server using server manager
> (or whatever that thing is)?
> No. We get into NT profile problems with that.
