Setup.exe - Entry Point Not Found
?SetRetryButtonText@CBaloonDialog@@QAEXVString@WTL@@@Z could not be located in the dinamic link library C:\Autodesk\Autodesk_Revit_2015_Italian_Win_64bit_dlm\Setup\SetupUi.dll
Any idea please?
I looked in a ton of forums, but no one was able to solve this..
Windows 8, 64 bit,
16 GBram
Nvidia Geforce GTX 770M
I7 Quadcore 4800 Q
Solved by Nicola_Ianeselli. Go to Solution.
I was not able to find a definite answer but in most cases, it appears that this problem is related to bad download of the Autodesk installer. With that in mind, my suggestion would be to rename or delete the C:\Autodesk folder (this ensure that a new instance of the Autodesk installer will be downloaded) and then run through the download/installation process again.
Tony Michniewicz
Autodesk Revit QA
DarrenP
uff....none of these is working unluckily...
i uninstalled c++, and reinstalled everyone of them... but nothing...
i tried downloading browser version... but nothing...
deleted and reinstalled C:\autodesk.... but nothing....
uff...
thank you for your support anyway!
Hello everybody!!!
Hope all of u had a nice time during Easter...
I found the solution of this issue!!
The only way u can solve it is to reinstall the OS... I reinstalled Windows 8, and after drivers the first software i put on my pc was Revit 2015!
Working!!!!
So great!!!
Have a nice time!!!
All of u!!
