Installation & Licensing
Problems installing Revit Architecture 2012 and Revit Structure 2012
1 REPLY 1
BIMBoy
257 Views, 1 Reply
After putting in the serial number and product key. the Revit screen indicates that the files were not successfully installed.
Really need the programes installing to prepare for an academic competition.
Many thanks
1 REPLY 1
TravisNave
in reply to: BIMBoy
Post the contents of your installation log file that appears on that install failed screen.  It will give you the reason for the failure.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Administrator Productivity
