Hallo all!
When want to install Autodesk Inventor Professional 2012, i clicked on setup.exe------------------------------->The system cannot find path. C:\Autodesk\SetupRes\eval.msi
Please help me. My English is not so good. And i need to install it!
Just some qustions and suggestions:
1 please check if you can find the msi file under the above mentioned path? just browse the path in windows explorer.
2 Did you install AIP from CD media? If yes,could you try to copy all the files into your hard disk with the sequence second disk overwrite first disk, same for others disks,then try to install from local hard disk.
