Installation & Licensing
Problem with Autodesk Inventor activation - broken activation window
3 REPLIES 3
pz_pollub
477 Views, 3 Replies
Hi. I downloaded a student version of Inventor. It works perfectly in try mode. However, when I try to activate it, after clicking "Activate" and later, "Continue", a broken window appears (image below). Is there a way to fix it, or activate the inventor in another way?
Windows 7 64 bit.
3 REPLIES 3
DarrenP
in reply to: pz_pollub
read this: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=6404339&linkID=9240617
there are also a lot threads on this already you can do a search on these forums to find them
DarrenP
afif90
in reply to: DarrenP
i also have the same problem with this..but im using winXP pro SP3..u nid to type sumthng in Command prompt..
Thank You&Best Regards,
Autodesk Reseller Malaysia
Mohd Afif
joane.bonghanoy
in reply to: afif90
Hi afif90 and pz_pollub,
Please PM me your Serial Number so I can look into it and troubleshoot further.
Joane Bonghanoy
Administrator Productivity
