Installation & Licensing
*Currie, Devin
Message 1 of 3 (109 Views)
Opened drawing for write on network
109 Views, 2 Replies
05-23-2000 09:50 AM
I am wondering if there's an alternative program to find out who has the
drawing opened for write on the network drive? I have dwglog.arx
but it makes a mess as it create the *.dwh files. I am not interest in the
log file keeping record of the drawing opened/closed. I am more interest
in knowing who has the drawing currently opened for write. Whether I
customized their AutoCAD workstation to load in the arx modules or not.
Should this not be an integral part of AutoCAD to identify the workstation
who has the drawing opened for write?
Devin
Active Contributor
Message 2 of 3 (109 Views)
Re: Opened drawing for write on network
07-05-2000 09:04 PM in reply to: *Currie, Devin
Devin, you can use the old WINFILE command at the DOS prompt and then select the offending file and use the
"Open By" button on the File Properties pulldown.
There is also an Autodesk utility called OpenBy.arx at the following address.
http://search.autodesk.com/support.html?col=adeskwww&rq=0&support=yes&product=10310&qt=openby
You will need ADMIN rights on the server to see the result in either case.
Regards Geoffrey Allen
alleng@mirvac.com.au
Member
Message 3 of 3 (109 Views)
07-10-2000 12:30 PM in reply to: *Currie, Devin
what's your NOS ?
for Netware we've been happy with whohas from ctyme.com
we paid about $100 for 1 f/s unlimited a few years ago
user needs admin rights; do just IT uses it
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Connect with Us
Twitter
Pinterest
Blog
Youtube
