A little while ago I recieved a new computer at work and I am no longer able to install my version of AutoCad 2008. I tried to reactivate my license and it said my serial number was invalid. I did not follow any procedure to transfer my license from my old computer to my new one. When I tried to use the installation wizard it did not work and I received an error message.
What do I do ?
This will explain it.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?id=22021115&linkID=9240617&siteID=123112
Good Luck!
I have not been able to launch AutoCad to use the activation wizard as required by the manual activation process. When I double click the "acad.msi" file the Installation wizard comes up and I click "Next". Then I get a message that says " Can't find end user license agreement ". I have a single 64 bit CD that I am using to try and install Acad 2008.
Wow, that is an old problem. I'll have to dig deep in my memory banks for that one. But I was thinking you had to copy the contents of the media to your local hard drive, then copy the EULA files to the right place. It's probably searchable here.
