Installation & Licensing
150 Views, 1 Reply
Network install
can anyone lend a hand with the licentfile and flexm...i cant seem to the
ther server to start
1 REPLY 1
if you have the licensefile information, save it to the license folder under
ADLM. Then start LMTOOLS. Change to Configuration using services. Then
switch to the Configure Services Tab. set the paths to the lmgrd.exe, the
licensefile and the debug file (make up a name for debug). Then check the
Use Services box and then the Start server at powerup. Then switch to the
Start/Stop/Reread -tab and press Start Server. You will see a text at the
bottom of the dialog saying Starting Server. It will never change, the
server takes about 30 seconds to start. You can check it by switching to the
Server Status tab and pressing the Perform Status Enquiry button.
HTH
Petri Ahava
CAD-Q, Finland
"Jaime" wrote in message
news:01c13605$86f36900$2c6464c0@pfieng04...
Administrator Productivity
