Installation & Licensing
Network Licensing Problems
6 REPLIES 6
ClaflinU
887 Views, 6 Replies
Currently we have Autodesk Education Suite for Architecture & Engineering 2011. W e have had it running for the last year. But recently the clients aren't able to obtain licenses from the license server. When I check the license server (LMTOOLS) and Perform Status Enquiry I get this following message:
[Detecting lmgrd processes...] License server status: 27000@cu-license     License file(s) on cu-license: D:\Program Files\Autodesk Network License Manager\Autodesklicense.lic:
cu-license: license server UP (MASTER) v11.7
Vendor daemon status (on cu-license):
  adskflex: The desired vendor daemon is down.  Check the lmgrd log file, or try lmreread. Vendor:Host:   cu-license License path:  27000@cu-license; FLEXnet Licensing error:-97,121 For further information, refer to the FLEXnet Licensing documentation, available at "www.acresso.com".
6 REPLIES 6
TravisNave
in reply to: ClaflinU
Have your licenses expired?  Or has there been any other changes to the server such as change of server hostname, domain, or network card?
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
ClaflinU
in reply to: TravisNave
The license had expired. There has been no changes to the server.
DarrenP
if the licenses expired you need to get another one
DarrenP
ClaflinU
in reply to: DarrenP
So without a new license there is no way for us to continue to use the software?
DarrenP
yea
if your license expired there is nothing you can do
you have to talk your educational license reseller
DarrenP
ClaflinU
Thank you for your help.
Administrator Productivity
