BoltaronITGuy said the following On 9/7/2006 2:19 PM:
> Sorry if this is an easy one but I am a noob to autodesk. I am the new IT guy here. We had autodesk installed on several desktops using the autodesk license manger. Unfortunately the license manager was run on a pc that no one "was shure what it does". The hard drive crashed and now I am lost. I was able to recover the license manager directory and the license key. My problem is I have no install cd that I know of. Since they cleaned house here and got rid of everyone. We only use autodesk on 1 computer now. Is there a way to put this license file on that pc. I already tried renaming the licensepath.lic file and letting it error out on me and pointing it to the new location of the file. That failed misserably. I either need to find a download of the license manager or figure out a way to make the license.lic file work on this pc.
> Thanks
> Bill
The NLM is on the AutoCAD media that you (hopefully) have.
If you are putting this on a new PC, you will need to get a new license
file from your reseller (you will need to supply the machine name, and
MAC address)
Then add this Windows environment variable to all client machines:
Var: ADSKFLEX_LICENSE_FILE
Value: @MACHINE_NAME
(where MACHINE_NAME is the actual machine name of the license server)
After the LM is set up correctly and started, then the client machine
should be able to pull a license with no problem.
R.K. McSwain
http://rkmcswain.blogspot.com
