after doing network teaming in the server the server host Identifer is different in the license file due to the fact that the mac address will be different from teamed orginal network card. Now license server fails with below info.
how can I get this solved.?
vendor daemon status (on Svbt8021):
adskflex: The desired vendor daemon is down.
Check the lmgrd log file, or try lmreread.
Vendor:Host: Svbt8021
License path: 27000@Svbt8021;
FLEXnet Licensing error:-97,121
For further information, refer to the FLEXnet Licensing documentation,
available at "www.acresso.com".
Solved by DarrenP. Go to Solution.
you need to unteam them
flex lm doesn't support teamed NIC cards
DarrenP
this still applies: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=7233453&linkID=9240617
DarrenP
