I am trying to install Autodesk Product Design Suite 2014 Trial on Windows 8 64-bit, and I keep on getting 'Network Failure' and 'Setup initialization failed' notifications and then promting me intall it again but still getting the same situation.
Has anyone had a similar problem? and if so, is there a solution?
Sorry to hear that you encounter issues installing the Product Design Suite 2014.
Try to download/install your suite directly from our "virtual agent", you should have the install package completely load on your local machine this way.
I hope it helps solve the issue.
