For 2014, can't you not any longer combine Navisworks Manage and Navisworks Freedom into a single deployment? It doesn/t show up when the deployment is being setup. ????
it shows up here
see attached
DarrenP
Agreed. I was going to mention the same as Darren. What are you seeing? Did you not get the full package?
I was hoping to install Freedom from Building Designer Suite Ultimate media and combine it with Navisworks Manage and Inventor. It doesn't show up on the Ultimate media.
@mdhutchinson wrote:I was hoping to install Freedom from Building Designer Suite Ultimate media and combine it with Navisworks Manage and Inverntor. It doesn't show up on the Ultimate media.
it doesn't show up on mine either
DarrenP
Do you suppose I could just find / download the exe or msi file and do 'Include additional software' option?
no clue
never used that option
thats a new feature in 2014 deployments
i guess its possible
DarrenP
I'm afraid you will need to create an additional deployment for navisworks freedom as it is not included with the building design suite installer.
You can download the Freedom installer from the below site
http://www.autodesk.com/products/autodesk-navisworks-family/autodesk-navisworks-freedom
The include additional software option in the deployment will not help in this case because the navisworks freedom installer is not a self contained install executable or msi file.
