HI !
ANY ONE COULD HELP ME WITH RE-ACTIVATION OF AUTOCAD LT 2007?
I NEED A NEW ACTIVATION CODE
THANKS!!!
Solved by grace.liu. Go to Solution.
You can use the online method to activate your license here:
http://knowledge.autodesk.com/installation-and-licensing
Or you can can call Autodesk Product Registration and Authorization:
1-800-551-1490 > Option 1 (English) > Option 1 > (Stand-alone)
You will need to provide your serial number and the request code.
Good Luck!
Hello CHELYAP,
Welcome to the Community!
Could you please send me a Private Message (click on my grace.liu profile name and then “Send this user a private message”) with your Serial Number ,request code and registratioin details ( eg, the company name and address ), I will help to activate the product manually.
I need to reactivate autoCAD 2007 as well...were you able to find any help?
Hello @belliott022 and welcome to the Community!
For licensing assistance, please contact our Activation and Registration team:
1. Visit http://knowledge.autodesk.com/contactus
2. Select “Activation & Registration” or “License Management”
3. Select appropriate subtopics from the pull-down menus.
4. Select “I Still Need Help” if you need personal assistance.
If you have any other questions or concerns please let us know. Thank you!
grace, i think i need your help, i sent something to your private message inbox, could you please have a look.
thank you very much.
