Installation & Licensing
Mudbox 2012 will not instal
4 REPLIES 4
Kevlarpaperclips
733 Views, 4 Replies
Hello, i have been trying to instal Mudbox 2012 Win 32-bit. Durring installation the installer will close near half way into the first phase and the instal will fail. The installation log file says a file is in use or something like that. I have tried installing in diagnotics mode, but the same thing happened.
I have attached the installation log file.
edit* I could not get the .txt file to attach correctly. So I will just type in the last part of the log file.
Any help would be greatly appreciated. Thank you.
The installation log file said
2011/7/26:17:11:14    HP_Administrator    PEPPER    === Setup started on PEPPER by HP_Administrator ===
2011/7/26:17:11:14    HP_Administrator    PEPPER    Launch
2011/7/26:17:12:20    HP_Administrator    PEPPER    PageOpen    LaunchDialog
2011/7/26:17:13:33    HP_Administrator    PEPPER    PageOpen    LicenseDialog
2011/7/26:17:13:42    HP_Administrator    PEPPER    PageOpen    ProductInfoDialog
2011/7/26:17:13:59    HP_Administrator    PEPPER    PageOpen    ProductSelectionDialog2
2011/7/26:17:14:08    HP_Administrator    PEPPER    PageOpen    FullProgressDialog
2011/7/26:17:14:09    HP_Administrator    PEPPER    Installing Autodesk® Mudbox™ 2012:  TRANSFORMS="C:\Autodesk\Mudbox_2012_EFGJ_Win_32-bit\x86\en-us\Mudbox\Mudbox2012.0.mst;C:\DOCUME~1\HP_ADM~1\LOCALS~1\Temp\_AI1E.tmp\x86\Mudbox\Mudbox2012.0-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Mudbox_2012_EFGJ_Win_32-bit\" INSTALLDIR="C:\Program Files\Autodesk\Mudbox 2012\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2011/7/26:17:14:42    HP_Administrator    PEPPER    Install    Autodesk® Mudbox™ 2012    Failed    Installation aborted, Result=1601
4 REPLIES 4
Hello there:
You may have issues with your Windows Installer.  Check out this MS Article and see if it helps:
http://support.microsoft.com/kb/315353
Todd M. Kane
Support Specialist
Product Support
Autodesk, Inc.
frhervet
in reply to: Kevlarpaperclips
What os did you use ?
Have you try windowsupdate before installation ?
Try :
1- msiexec /unreg
2- msiexec /regserver
Franck Hervet
S'il vous plaît Marquer cette réponse comme "Accepter comme solution" si elle répond à votre question.
That fixed it. Thank you both for the reply. Now I just have to figure out how I messed up my Windows Installer so I don't do it again.
I cannot install Mudbox. I am trying to download the free trial to try it out, but I keep getting the same error message over and over over and over again...regardless of where I try to save it. The message is "try again in a new location"
WHERE am I supposed to try and save this? I have tried making a folder, tried saving it to an existing folder, tried saving it to desktop...WHERE do I save it?
Administrator Productivity
