Installation & Licensing
*Fisk, Justin
Message 1 of 30 (106 Views)
More ADT2 WIN 2k network problems
106 Views, 29 Replies
06-23-2000 06:33 AM
Hello again,
I thought I had my problem licked with the install of the dll update
for ACAD 2000 but I don't. Now when I invoke any of the ADT commands I
get the following errors:
"Unable to send License daemon message"
followed by:
"License check failed"
Before the dll update I could not even start ADT2 but it will now start
but when it initializes ADT I get the error above. Please help me
again.
Justin Fisk
*milana, jerry
Message 2 of 30 (106 Views)
Re: More ADT2 WIN 2k network problems
06-26-2000 11:05 AM in reply to: *Fisk, Justin
Justin,
Are you setting ACADSERVER? If you are, check the case of the variable's
value as the setting is case sensitive. While AutoCAD may find the AdLM
server without an ACADSERVER variable set or set incorrectly, the ADT module
requires that this variable be set properly.
jerry
"Justin Fisk" wrote in message
news:39536723.46C2268D@csd-eng.com...
> Hello again,
> followed by:
> again.
> Justin Fisk
*Fisk, Justin
Message 3 of 30 (106 Views)
06-26-2000 02:34 PM in reply to: *Fisk, Justin
Didn't work, I did not have it set before but I have it set now. FYI, I am
using the TCP/IP version of the ADLM. Can an IP address be assigned to the
ACADSERVER Varible or does it have to be a machine name? I tried both but
no fix. What else should I try?
Justin Fisk
Justin Fisk wrote:
> Hello again,
> followed by:
> again.
> Justin Fisk
*Martin, Jason
Message 4 of 30 (106 Views)
Re:
06-26-2000 02:47 PM in reply to: *Fisk, Justin
As Jerry has corrected me on before it should be set to the host name of the
machine running the adlm.
hth
jason martin
frankfurt-short-bruza
Justin Fisk wrote in message
news:3957CC80.62C3F1F1@csd-eng.com...
am
the
> Justin Fisk
> Justin Fisk wrote:
> > Hello again,
> > followed by:
> > again.
> > Justin Fisk
*milana, jerry
Message 5 of 30 (106 Views)
Re:
06-26-2000 04:27 PM in reply to: *Fisk, Justin
Jason is correct, you must set ACADSERVER to the hostname of the license
server. The hostname is displayed in the DNS tab of TCP/IP properties.
Generally speaking, the hostname will be lower case where the machine name
will be uppercase. Also, in order for all of this to work, you must be able
to ping the AdLM server by hostname from the workstation and ping the
workstation by name from the server. IP address is not good enough. Also
remember that on Win 95 and 98 you must set ACADSERVER in Autoexec.bat and
the workstation has to be rebooted.
jerry
"Jason Martin" wrote in message
news:ef2569d.2@WebX.SaUCah8kaAW...
the
> hth
> jason martin
> am
> the
but
> > Justin Fisk
> > Justin Fisk wrote:
> > > Hello again,
update
I
> > > followed by:
start
> > > again.
> > > Justin Fisk
*Fisk, Justin
Message 6 of 30 (106 Views)
Re:
06-27-2000 10:30 AM in reply to: *Fisk, Justin
I did this... the machine name and the hostname are the same on this machine.
And again this is a Windows 2000 machine! What else can I do. Is anyone else
having this problem or am I the only one?
Justin Fisk
> jerry
> the
> > hth
> > jason martin
> > am
> > the
> but
> > > Justin Fisk
> > > Justin Fisk wrote:
> > > > Hello again,
> update
> I
> > > > followed by:
> start
> > > > again.
> > > > Justin Fisk
*Portman, Jeff
Message 7 of 30 (106 Views)
Re:
06-28-2000 06:33 AM in reply to: *Fisk, Justin
Justin:
Can't help you, but I can confirm that you aren't alone - I'm having the
same problem.
Jeff
news:3958E4C1.156D3C0E@csd-eng.com...
machine.
else
> Justin Fisk
*martin, jason
Message 8 of 30 (106 Views)
Re:
06-28-2000 06:51 AM in reply to: *Fisk, Justin
I know this isn't what you want to hear but build a NT4 box out of a 486,
install adlm and set it in the corner. The only time we connect a monitor
to ours is to install an NT service pack.
Not much help but it will work.
jason martin
Jeff Portman wrote in message news:ef2569d.5@WebX.SaUCah8kaAW...
> Justin:
> same problem.
> Jeff
*Fisk, Justin
Message 9 of 30 (106 Views)
Re:
06-28-2000 12:49 PM in reply to: *Fisk, Justin
I am assumeing that the server has nothing to do with it, I have ACAD LT98
ADLM running on the same machine and it works fine. BTW the our ADLM machine
is Windows 98 based Pent 75. (it works great). This is a windows 2000
problem.
Justin Fisk
> jason martin
> > Justin:
> > same problem.
> > Jeff
*Portman, Jeff
Message 10 of 30 (106 Views)
Re:
06-29-2000 06:16 AM in reply to: *Fisk, Justin
Jason:
I'm actually running that configuration: NT4 server hosting adlm, Win2k
workstation running ADT2, and I still can't get a license for the ADT2 part.
So I have to agree with Justin, it appears to be a Win2k problem (or a
problem with how Win2k talks to every other operating system).
Are you actually using this configuration successfully?
Jeff
"jason martin" wrote in message
news:ef2569d.6@WebX.SaUCah8kaAW...
> jason martin
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Connect with Us
Twitter
Pinterest
Blog
Youtube
