We are experiencing several workstations that have a video issue that causes the monitors to blink when opening Autocad. This also occurs when trying to print to our Oce. This may be related to a video driver update since the problem occurred on one workstation after an Nvidia update, but not on another. This does not occur when opening Revit.
We have reinstalled chipset and nvidia drivers to no avail.
Has anyone else experienced this?
Lenovo w520 and w530 w/ Quadro 1000m + 16gb ram.
Log from a user experiencing this issue:
I noted every time the monitors flashed yesterday. Here’s what happened:
Solved by kevin.carroll. Go to Solution.
If you have an onboard video and then also a secondary real graphics card, it might be switching. You can either set your AutoCAD to always use the real video or always have Windows use the real video card in general. See my Optimus link about this, it might have some insight.
Also, definitely check nvidia.com for the latest WHQL drivers.
Sorry, it is in my signature. Here is the link.
