Hello good folks,
I am having a bit of a predicament with Maya not launching. I keep getting a licensing error message when I can't get the product to start the Activation or Registration screen. The error message I get is this:
AdlmInt Error: The AUTODESK_ADLM_THINCLIENT_ENV XML file could not be loaded
license problem in GUI mode launch dialog message.
No matter how many times I reinstall the product the same message keeps appering. I can't activate the product without Maya starting normally. So what can I do?
Are you activating a trial install? You may need to edit the License.env, which is located at:
Windows:
For Maya 2011 - C:\Program Files\Autodesk\Maya2011\bin\License.env
Linux:
/usr/autodesk/maya2011-x64/bin/License.env
Mac:
/Applications/Autodesk/maya2011/Maya.app/Contents/License.env
Edit the file to read the following:
MAYA_LICENSE=unlimited
MAYA_LICENSE_METHOD=standalone
You should also then install the latest service pack.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=18428455&linkID=9242259
I found the solution to this little problem. It wasn't anything related to the Licensing but the way you install the software itself. My mistake was extracting the RAR file and I didn't notice the small detail, "Application." So because of that I had numerous amounts of problems that I only frustrated myself for not noticing sooner.
Thank you for giving me guidance on additional information.
Cheers mate
