Installation & Licensing
*Sanjay Goel
Message 1 of 1 (36 Views)
MOving to new server
36 Views, 0 Replies
03-15-2004 07:40 PM
Hi Everyone.. I'm trying to move the adlm for Architectural Desktop 2.0 (the package includes autocad2000) from our old server to a new computer (we've upgraded our servers and need to decommission our old ones). I have installed the adlm software on the new computer and sent the server code + original serial numbers to get authorisation codes. I have put in the authorisation codes succesfully, and enabled both features. The problem is that it does not seem to be giving out licenses. I have launched the service from the control panel (AdLM icon), and verified that the service is running (under services listed as "Autodesk License Manager" currently started and set to automatic). However, it doesn't seem to be functioning. I did some troubleshooting with the NETSTAT -n -a command and noticed that on the old server, the machine is listening on port 1422. This is the line displayed when running netstat -n -a Proto Local Address Foreign Address State TCP 0.0.0.0:1422 0.0.0.0:0 LISTENING When I stop the service using the AdLM icon in control panel, then run netstat -n -a again, the entry is no longer listed. When the service is started again, the entry reappears. It seems like the computer needs to be listening on port 1422 (the default adlm port) for it to give out licenses. However, the new server doesn't seem to be listening on this port when i check with netstat. AdLM Query utility displays the new server as active, but the clients fail to start up Autocad 2000. Any ideas or suggestions on overcoming this technical glitch? Thanks
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Connect with Us
Twitter
Pinterest
Blog
Youtube
