Installation & Licensing
MDT 2009 cannot find Inventor 2012 [ Install fail ]
2 REPLIES 2
tlebrun
1009 Views, 2 Replies
* Windows 7 64bit SP1 fresh install * Logged in as an admin / full admin rights * Inventor 2012 Ultimate / Mechanical 2012 installed * 10+ year subscription with Autodesk * legit MDT2009 key (390-XXXXXXXX) * Same MDT2009 files I used to install it a dozen locations in the past Failed to install MDT 2009 (yes, we still need it) [see attached] "Autodesk Inventor was not found on your computer....................... with Inventor running in the background :rolleyes: Hello Monday... hows it going? Ugg.
2 REPLIES 2
emily.xu
in reply to: tlebrun
Did you download the new MDT installer compatible for Inventor 2012 at http://usa.autodesk.com/adsk/servlet/pc/item?id=13744274&siteID=123112?
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Emily Xu
Product Support
tlebrun
in reply to: emily.xu
Well, I downloaded the new MDT2009 files per the link above but could not, for the life of me, get around the infamous....
"Failed Installation aborted, Result=1603"
Gave up with those files, installed Inventor 2010, then installed MDT2009 from my 2 year old zip files, then uninstalled Inventor 2010 and all is well.
(I wonder what the difference between these sets of MDT2009 installation packages are)
Administrator Productivity
