I am considering upgrading from AutoCAD LT 2012 to the full version of AutoCAD this year. Will it be necessary to completely uninstall LT first or will the full version install over the top of it with no problems?
Dave
Solved by DarrenP. Go to Solution.
i would uninstall LT first and clean any remaining folders and registry keys
you can actually use this tool to do it if you want: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=17031128&linkID=9240617
if you don't want to use that tool go this route: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=2887771&linkID=9240617
DarrenP
Thanks for those links, Darren! I'm glad I asked first. I've always had good luck personally with AutoCAD installations, and hope to keep it that way.
Dave.
