Can we use the Instructor Station which needs to run AutoCad as the license manager as well?
Solved by TravisNave. Go to Solution.
Solved by hashim.mundol. Go to Solution.
Yes as long as the system requirement matches this
Yes, it will work fine. If the instructor station is Windows Vista, Windows 7, or Server 2008, you might have an IPv6 issue. That can be easily resolved by modifying the LICPATH.LIC file to include 127.0.0.1 instead of the hostname. Or you can try my other methods below.
For more information about Network License Manager connectivity issues and IPv6, please see my discussion post here:
http://forums.autodesk.com/t5/Installation-Licensing/Network-License-Error-1-5-15-and-IPv6/td-p/2982...
