Installation & Licensing
Inventor Help Installing failure
1 REPLY 1
wasp95
223 Views, 1 Reply
Hello;
I ask any of you in the forum help with the installation of Autodesk Inventor.
Let me explain the situation ...
I installed inventor 2011 but then recently I uninstalled normally.
the whole procedure was done accurately.
days ago I wanted to install nuyovo inventor,
whatever was the version, but I riscontrava a problem.
said that the key:
HKEY_LOCAL_MACHINE \ SOFTWARE \ Microsoft \ Windows \ CurrentVersion \ App Paths \ Inventor.exe
With error message: Access is denied to the key.
I tried in every way to uninstall uninstalling the inventor but I did not note
installed.
removing the key manually, but to no avail I get the same error message
1 REPLY 1
dembkod
in reply to: wasp95
Wasp95,
Hello. It looks like you do not have the proper permissions to machine to make the type of edit to the registry the install needs. This could be due to restricted permissions on the account through the system or possible policies from your organization. There could also be a system corruption that is preventing the rights form being utilized correctly on your system.
I would check your user permissions to make sure you have full admin rights, or try to log in with another user account that has full admin rights and install form that account.
Thank you for taking part in our community!
David Dembkoski
Product Support Specialist
Autodesk Product Support
David Dembkoski
Administrator Productivity
