Hi all,
when I try to install inventor 2014 from the student free downloads, I get an error message reading
Error 1308. Source File not found: C:/Autodesk/WI/Autodesk Inventor 2014/x64/inventor/Program Files/Autodesk/Inventor 2014/Bin/Mb.dll. Verify that the file exists and you can access it.
I then searched manually for the file. I found all the other Mb files but not the one I was searching for. I've gone through the process multiple times and download new inventor downloads.
How do I solve this problem? Do I need to get a copy of the file?
Solved by dembkod. Go to Solution.
Solved by TravisNave. Go to Solution.
Try redownloading it instead from the virtual assistant:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=21889745&linkID=9240617
Good Luck!
I followed the instructions and downloaded Part 1 from the virtual assistant. When I select the destination folder, I get an error message saying
Product download consists of multiple files. At least one file is missing or has not been downloaded yet
Anything else I can try?
Hello. Part 1 is just part one. You need all parts first. Download them all and see if it helps.
Thank you for taking part in our community!
Hi there,
Sorry for not being able to understand fully. But I also have the same problem, except, Travis, when i click on that Link, it just takes me to download AutoCad?
If you would be able to do a step by step guide here, i would be really greatful. Currently got a Project due for next week and it's just not working! 😞
Ryan.
Hello!
I'm trying to set up Inventor 2014 Toshiba Laptop but I got a pop box after a while of appearing the Inventor installer. I tried EVERYTHING of what it says, but I don't know. I almost crash up my computer and I feel so up set of not knowing what to do. PLEAAAAAAASE HELP!
http://knowledge.autodesk.com/support/inventor-products/downloads#?sort=score
I believe this is the link that you are looking for.
I have problems with the installation of Inventor on 2014 on my pc. I had already downloaded it then I reformatted my computer. Now, when I install it
again, I receive error messages. Could you help me please?
Hi @t_e07 and welcome to the Autodesk Community!
Please, disable your firewall and anti-virus programs and download the software from our Virtual Agent linked here (click on Download Links, choose product and version).
I hope this helps!
Thank you, it's ok for Inventor 2014. Now, To install Autocad 2014, I always have the serial number but I lost the product key. Could you help me please ?
