Installation & Licensing
Inventor 2013 SP2 will not apply
2 REPLIES 2
s.mccarthy
340 Views, 2 Replies
Several attempts to apply the msp have been unsuccessful. The admin account was used each time, and after 45 minutes of seeing this (each attempt), I gave up.
Is it normal for the service pack to take this long to be applied?
TIA
Win7 x64 Pro
12G RAM
i7 920@2.67
2 REPLIES 2
TravisNave
in reply to: s.mccarthy
Service packs can be quite large and long to install.  Do you get an error?
Are you certain that your Inventor isn't already SP2?
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
I have the same issue. Installation starts and goes about 80%, stalling on copying files. Checking through taskmanager shows that there is absolutely no activity from the installer process(es) whatsoever.
Alex
XP Pro 2002 - SP3
Intel Xeon
Administrator Productivity
