AFAIK, FLEXlm is backward-compatible with older versions. It should be safe
to update to the latest version of the services without affecting existing
lmgrd's. I don't know of any way to do a side-by-side install of different
versions on the same server.
--Cy--
wrote in message news:4822555@discussion.autodesk.com...
>A previous thread discussed updating FLEXlm with the update to AutoCAD 2006
>and one user said that they had installed the new v10.1.5 while leaving the
>old v9.2 in place so they could migrate. I attempted installing in this
>manner and the install wouldn't go because it said that I had to remove the
>current one.
> Is this a problem because I still have the individual lmgrd's running (I
> have several software products under FLEXlm)? If I just stop all of the
> FLEXlm services will I then be able to go forward with the v10.1.5
> install? And upon completion will v9.2 still work the same as before?
> Whew, that's a lot of questions - hope someone has the answers.
> Thanks in Advance
> Jay
