I'm trying to install Autocad 2010 on my Windows 64-bit professional with Directx 9.0c (version 4.09.0000.0904)
and for some reason it will not recognize I already have the directx needed to run Autocad 2010 so when it attempts to reinstall it says:
"An internal system error occurred.
Please refer to DXError.log and DirectX.log in your Windows folder to determine problem."
The DxError.log says:
[09/13/10 11:01:37] module: dxupdate(May 30 2008), file: dxupdate.cpp, line: 2398, function: RunProcess
Failed API: CreateProcess()
Error: (193) - %1 is not a valid Win32 application.
[09/13/10 11:01:37] module: dxupdate(May 30 2008), file: dxupdate.cpp, line: 3415, function: InstallEXE
RunProcess() failed.
[09/13/10 11:01:37] module: dxupdate(May 30 2008), file: dxupdate.cpp, line: 5816, function: DirectXUpdateInstallPlugIn
InstallEXE() failed.
[09/13/10 11:01:37] module: dsetup32(May 30 2008), file: dxupdate.cpp, line: 280, function: CSetup::InstallPlugIn
DirectXUpdateInstallPlugIn() failed.
[09/13/10 11:01:37] module: dsetup32(May 30 2008), file: setup.cpp, line: 1701, function: CSetup::SetupForDirectX
InstallPlugIn() failed."
Any ideas?
