Installation & Licensing
Installation of Revit MEP 2013
1 REPLY 1
jkkagalkar
378 Views, 1 Reply
I am trying to intall Revit MEP 2013 on windows 7.0  32 bit.. I get the following errors:
1:5:2: adlmPTSetProductInformation failed: 3:2
Error 1712 : One or more of the files required to restore your computer to its previous state could not be found. Restoration will not be possible.
Note:
Antivirus software is disabled.
I have admin rights
this is a fresh install
Revit RAchitecture 2013 was successfully installed few days back.
windows update has been done.
Thanks and Regards,
Jayatheertha.K.Kagalkar
Tags (1)
1 REPLY 1
TravisNave
in reply to: jkkagalkar
You might have to delete the ProductInformat.PIT file.
You can also research here:
https://www.google.com/#q=site:autodesk.com+1:5:2:+adlmPITSetProductInformation&hl=en&prmd=imvns&ei=...
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Administrator Productivity
