Hi, I downloaded the software fine but after trying to run in it says it's not recognized, does anyone know what to do? I included a pic of the pop up window in case it helps.
Thanks!
Solved by philip.s. Go to Solution.
Can you try again using the timed direct download link below and confirm that you meet the system requirements. What OS version are you running?
Autodesk Smoke 2012 Mac - LINK
Hi, thanks for taking the time to help me!
I just tried to download it through the regular downloading (not student) and it asked me to download an installer and nothing else happened after it was don.e
Actually I just tried it again and it downloaded fine but now I tired to put inthe serial number and product key but the "continue" button isn't available.
Can you please PM me your serial number and the product key you are using so that I can verify accordingly.
