Installation & Licensing
Welcome to Autodeskā€™s Installation and Licensing Forums. Share your knowledge, ask questions, and explore popular Download, Installation, and Licensing topics.
Showing results forĀ
ShowĀ Ā onlyĀ  | Search instead forĀ
Did you mean:Ā
nd.g
849 Views, 1 Reply
Installation failed
I'm trying to install AutoCAD 2012 onto my computer (I have Windows Vista Home Premium 64bit) but each time it comes up saying that it failed to install. An error appears about half way through installation and then the number of items installed appears to go down (i.e. whereas it might have said before that 5 out 10 are left to install, it will then say that 6 are left, then 7 etc). I have tried to install the 2011 version, but this also had the same problem. I have copied the installation log below and would appreciate any helpful suggestions.
ProductSelectionDialog2
2011/10/14:16:54:23 Nick NICK-PC PageOpen FullProgressDialog
2011/10/14:16:54:23 Nick NICK-PC Installing DirectX Runtime: C:\Autodesk\AutoCAD_2012_English_Win_64bit\3rdParty\DirectX\DXSETUP.exe /silent
2011/10/14:16:55:41 Nick NICK-PC Install DirectX Runtime Succeeded
2011/10/14:16:55:41 Nick NICK-PC Installing FaroSDK: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2011/10/14:16:56:09 Nick NICK-PC Install FaroSDK Succeeded
2011/10/14:16:56:09 Nick NICK-PC Installing Autodesk Material Library 2012: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2011/10/14:16:57:01 Nick NICK-PC Install Autodesk Material Library 2012 Succeeded
2011/10/14:16:57:01 Nick NICK-PC Installing Autodesk Material Library 2012 - Low Resolution: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2011/10/14:16:57:50 Nick NICK-PC Install Autodesk Material Library 2012 - Low Resolution Succeeded
2011/10/14:16:57:54 Nick NICK-PC Installing AutoCADĀ® 2012: TRANSFORMS="C:\Autodesk\AutoCAD_2012_English_Win_64bit\x64\en-us\acad\acad.mst;C:\Users\Nick\AppData\Local\Temp\_AI6FD2.tmp\x64\acad\acad-standalone.mst" MSINEWINSTANCE=1 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2012 - English\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2011/10/14:17:05:25 Nick NICK-PC Install AutoCADĀ® 2012 Failed Installation aborted, Result=1603
2011/10/14:17:06:24 Nick NICK-PC Rollback Autodesk Material Library 2012 - Low Resolution Succeeded
2011/10/14:17:08:06 Nick NICK-PC Rollback Autodesk Material Library 2012 Succeeded
2011/10/14:17:08:12 Nick NICK-PC Rollback FaroSDK Succeeded
2011/10/14:17:08:12 Nick NICK-PC Rollback DirectX Runtime Failed Failure is ignored, Result=1619
1 REPLY 1
TravisNave
in reply to: nd.g
There is no need to double-post.  Let's keep them all in this one spot:
http://forums.autodesk.com/t5/Installation-Licensing/AutoCAD-Failed-to-Install/td-p/3192392
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Administrator Productivity
